blocks in the front
Discussion in 'The Garage' started by blazerpro79, Mar 7, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    why is it dangerous to run blocks in the front? im not considering it because blocks are ghetto as hell, but just wondering.
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Because they arent part of the leaf spring pack nore part of the axle. They can get squeeze out, I saw it happn about 4 months ago at a mudbog, and it wasnt a boggin truck..it was someones DD. Just generally unsafe.
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I may be wrong, but I always though it had to do with the fact that so much of the trucks weight is up front.. and then having the "stack" effect of a block sandwiched between the axle & springs could cause failure. Like what AKMUDR said...
    I blelieve the reason they are "ok" in the rear is that there is less weight, and in addition, the vehicle is "pulling" the rear axle over obsticles (plus it's drive input) where as the front sort gets "pushed into" obsticles. It's sort of hard to explain.. :confused: :grin: Pushing the front axle into the obsticle places a great amount of laterial stress on the front suspension... and with blocks, the added leverage would/could work against the system and cause it to shear, break, or come apart.
    Something along those lines anyway... I know what I'm trying to say.. just not sure I'm making it understandable for everyone else. :blush: :crazy:
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The reason is because the front axle steers. The forces of steering can easily break, spit out, etc. a block and that is why it is unsafe.
  5. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    this is kinda off topic, but remember back in the day before we has these fancy lift springs guys would lift their trucks with blocks?..well some still do, but i remember years and years ago seeing dozens of trucks with two 4 inch blocks stacked on top of each other to get their big lift...or maybe that ws just a california thing? lol
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, we have learned over time. Blocks up front aren't a good idea. That said, a "block" that was properly welded to the spring perch (or just a whole new perch that was taller by design) shouldn't be a problem.
    j
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    What is different (besides size) when using a zero rate on the front? It may be just size reducing the force place upon it, but i'm just wondering because I am considering moving mine from the rear to the front and getting lift springs for the rear (rear is sagging).
  8. AkMudr
    Dec 30, 2004
    917
    Alaska
    Zero rates are bolted to the spring pack and are safe becuas eof that, and because of they are only 1". Lift blocks float between the spring and axle and arent secured by by anything except weight and the ubolts.
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    A lift perch is okay to a point. You still have a leverage issue on the u-bolts. They tend to snap under that type of loading.
  10. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Just a general observasion...
    Every big rig I have worked on has front blocks on the steering axle (3-4"?)
    I have never heard of them loosing a block unless it was in a severe accident
    Alot of these trucks go a million miles in their service life without a problem
    Now I just wonder how they get away without problems , is it because it's just a steering axle with no forces applied to it by 4X4 running gear
    There must be a lot of forces involved steering a loaded rig around?
    I agree that front blocks are not a good thing in a 4X4 and was just wondering about the rigs???
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    true dat. Im talking about an inch... maybe two. There are definitely limits. Lots of guys running rockwells have pretty high perches tho...
    j
  12. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I've made the same point everytime someone talks about braking torque on front axles and blocks. Most big rigs I've driven has had front blocks.
  13. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I had a j4000 with 2.5" blocks in the front, welded to the perch, it seemed to where out ball joints fast but I dont know if that was why. The whole truck was micky mouse
