blocks numbers on 350 and 305
Discussion in 'The Garage' started by muddyblzr, Jun 2, 2005.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    when i bought my 85' pickup the previous owner gave me an engine that did not come out of it at the time i didn't ask what it was becuase i was planning on gettin a tbi 350. but before i could buy it someone else got to it. so heres the questions. what physical differences are there between teh 350 and 305 and what are there block numbers??
    any info is much appreciated
  2. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    you post us the #s and then we can go from there easyer. and both use the same stroke crank but smaller bore on 305.
  3. muddyblzr
    Nov 2, 2004
    623
    k ill b able to get them 2morrow when i go work on it. are there any exterior differences that are easy 2 spot?
  4. sweetk30
    Nov 1, 2004
    25,536
    532
    best option and most true is the block #s on driver side at bell housing lip.
  5. muddyblzr
    Nov 2, 2004
    623
    k ill check it 2morrow and see what i find. shouldnt b 2 hard ther is no front clip. hopefully its a 350 so i have somethign to run.
  6. muddyblzr
    Nov 2, 2004
    623
    does anyone know the block numbers for a 305?? i found a 350 in a junkyard and wrote down the block numbers and they read 3970010. from what ive read that is a 350. it was in a pickup but the cab was completely off.
  7. sweetk30
    Nov 1, 2004
    25,536
    532
    looked in my book and must be over 18-20 of them.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  9. muddyblzr
    Nov 2, 2004
    623
    awesome thanks alot for all the info and link helped big time. now all i gotta do is go look at my engine and see what she says. hopefully its the number i tagged from the junkyard. the truck look to be a mid 80s from how the bed sides were.
    thanks again
  10. divorced
    Jul 20, 2004
    5,115
    No problem on the links. That site has a lot of good info, including casting numbers for heads and crankshafts.
