Blocks or similar to ORD zero rates?
Discussion in 'OffRoad Design' started by Storm24m, May 13, 2002.
  1. Storm24m
    Storm24m 1/2 ton status
    Mar 12, 2002
    148
    Knob Noster, MO
    Can someone check out this pic and tell me if this is something similar to an ORD Zero rat or if some dumb@$s put blocks under the front springs?
    http://community.webshots.com/photo/36559866/36560723imFKZs
    If you can't tell by the pics, is there any way I might be able to short of taking things apart?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Look's like a homemade block..
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Could those be degree shims?
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    if they are tapered , wedge shaped , then they are probly degree shims . i cant think of a way to tell without take it apart , u might droop it out as far as it will go and see if u can see a bolt all the way throo...but probly not .
  5. 73 Heavyd
    73 Heavyd Registered Member
    Jan 28, 2002
    38
    South Dakota
    Don't you have to cut the top plate for the new pin location if you use the "0" rates? If so, is there a modified top plate? Just an idea.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Basically the only way to tell is to take it apart. Not much else to do with it.
