blocks Vs zero-rates
Discussion in 'The Garage' started by GMC500, Apr 3, 2006.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hello all
    what are the differences between blocks and zero-rates?
    and why it is OK to use zeros in the front while blocks aren't suitable ?
    and can you please support your posts with pics
    thanks
    Ahmed
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Blocks get places between the axle and the spring, nothing other than the u bolts hold them in place. The u bolts can loosen and spit the block out. Not good. A zero gets bolted to the spring pack like it's a spring, but since it doesn't have the lenght to support any weight, can't call it an add-a-leaf. If the ubolts do loosen with zero rates, they won't spit out because they are bolted in.
  3. GMC500
    Aug 19, 2005
    203
    Safwa
    thanks for the explanation
    how big can I go with zero-rates (Safely) 1",2" or 3" ?
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    In the front, I wouldn't go any bigger than 1"
  5. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Not really sure, I was kinda wondering this myself. I personnally don't run them, don't need them just yet. But I want to do a SAS in my 97, I have the ORD shackle flip for the rear, and need more than the 4" it gives, so I thought about a 2" one with the offset to lift a little more, and relocate the axle. I would think that 2" would be the max, inless you run a traction bar or something similiar to keep axle wrap down.
