Blocks
Discussion in 'The Garage' started by chris12, Sep 12, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    Hi im trying to decide what i should do. But what are the advantages and disadvantages of blocks.
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    the good thing is they're simple. the bad is, if they're too tall you get axle wrap. if they are for you depends on how tall of a block, how much power, and tire size
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Never ever run them in the front!
  4. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    if that is your truck in your avitar, dont use blocks. yea, its cheap, and gives you quick results, but lift springs or a shackle flip is more worthwhile. PS. Love the front bumper. Can I have it?
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Blocks also love to work the u-bolts loose and either break into pieces or just fall out. This usually ends in failure of the u-joint/driveshaft. Get a shackle flip for the rear, they aren't expensive.
  6. chris12
    Apr 23, 2006
    267
    Alright I 'v made up my mind i going to put the 4" lift springs in the front to bring the truck up to level. Then il do a shackle flip on the rear for the extra 4" and look for a set of maybe 6" lift spring for the front to level it back out.
    What do you all think
  7. chris12
    Apr 23, 2006
    267
    Well i have the dual exhaust on my truck that comes out either side of the rear wheels they come out at a 45 on each side now if i do a shackle flip will my exhaust need to be modified. Can post a pic if needed
  8. chris12
    Apr 23, 2006
    267
    Here are two pics the quality is not the best on the one but hopefully it helps.
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    you maaaaay need to reroute it, but ive seen people run it above the leaves without issue.
    if it were my truck, i'd ditch the tips altogether IMO
  10. chris12
    Apr 23, 2006
    267
    Thanks for the reply but the truck looks good with the tips and what not when you can stand behind it and see it on both sides.But everyone has there on opinion
  11. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah i agree they can look pretty good, but i mangled the tips on my truck doin some light wheelin:haha:
