Blow-up picture or step by step for 14bff
Discussion in 'The Garage' started by XHitman396, Jul 9, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    anybody gotta blown up picture of a 14bff, or at least one drum. I finally got one and realized i wasnt sure how to get to the brakes. i got the axle off and figured i better wait to go on. if not, can you do a step-by-step of how everything comes off?? thanks guys..
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here ya go
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if press-on drums.
    after it's jacked up and the wheel off.
    removed axle shaft
    then remove spindle nuts
    pull off drum/bearing hub
    there are the brakes.
  4. XHitman396
    May 3, 2002
    620
    how do you get the spindle nuts off??
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    You need a 6 prong spindal nut socket. Like 15$ at the part store
  6. XHitman396
    May 3, 2002
    620
    damn... that would explain it though, thanks for all your help guys...
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    A punch or drift pin will work in a pinch.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Usually there is a locking ring in there with tabs on it that are bent into the notches on the spindle nut. You can use a screwdriver to bend them out of the way... then go at it with the 6 prong socket.
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    or your once favorite flat blade scewdriver:doah:
