Blower Blazer ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Andreas, May 7, 2000.
  1. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    This may sound a bit weird, or just plain ridiculous but I´m thinking of putting a Gmc 4:71 blower on my 406cui. I found one really cheap and thought "what the h*ll". I wont charge it much, just to give a little bit of whine and oomph, and they look so cool [​IMG]. Anybody tried this in a Blazer ? Any overall thoughts concerning blowers? Thankful for any input.
    Andreas
    406cui of pure sh*t[​IMG]
  2. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    if you dont lower the compression you wont get the maximum effect, but Youll still feel a noticible difference, youll probably have to run high octane gas too and that could get expensive with a blazer. youll also need a new cam
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    is it a 471 right off a truck? they dont have the correct drive setup for you to use. can get very expensive to convert one to work properly. I am putting a B@M supercharger on my blazer. bought it used from a friend for 600.00. no hassle, just bolt on and go faster.I would look around for other options before atempting this. it could cost alot more when your done. some blower drives won't take power steering and other accessories. lots of time spent to make things fit!! I work on diesels, have tried this game before. alot of headaches.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I was coming home from a truck show down the shore last fall and saw a K5 in the gas station. It looked normal enough, but the guy opened it up and it had a blower. he said he had 6:1 pistons and a special cam. he said it was really fast</font color=blue>
  5. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    If your compression is around 8.0:1 to 8.5:1 you sould be able to run 3-5 pounds of boost safely.Remember that timing sould be retarded.
  6. 73/75 k5
    73/75 k5 Registered Member
    Mar 18, 2000
    38
    ca
    I saw one on a 75 chevy stepside 4x4. It looked cool and you can definitly hear it coming down the road. Single carb setup and it all fit nicely under the hood without a cowl induction hood or scoop. He claimed it ran in the mid 13's and would smoke some of the local 5.0's. Watch out for smog if it's not exempt. I think it was a Weiand setup.
    good luck!
