blower control switch
Discussion in 'The Garage' started by blazerjake86, Oct 12, 2003.
  1. blazerjake86
    blazerjake86 Registered Member
    Oct 12, 2003
    19
    for some reason myblowers control switch does not work. my blower works i even put a new relay in it. for now i have a switch hooked up and it blows full blast when on or not at all when off. could i have just gotten a bad relay? when i turn the control box to off it goes off so i know that works any ideas?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    two words....
    BLOWER RESISTOR!
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    same problem I have. Seems like my full blast could be stronger too.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I have had the problem before of the fan only working on full speed. The relay mounted on the side of the A/C evaporator box was bad. That thing is SPDT switch. It switches the blower motor between either full 12V or the blower resistor. One side of the contacts wears out and you lose all of the lower speeds.
    You can bypass it temporarily to see if the problem is the resistor or the relay. You can take the relay apart if you're careful and clean the contacts. However, I find that to only work for a few more months.
  5. blazerjake86
    Oct 12, 2003
    19
    ok where is the blower resistor at i know where the relay is but not the resistor please help
  6. blazerjake86
    Oct 12, 2003
    19
    i found the resistor. the next question i have is can you buy these things at any auto parts store?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    can you let me in on where the resistor is?
  8. blazerjake86
    Oct 12, 2003
    19
    it is on the air comd box. it has two nuts and then it pulls out it has three springs its above the relay
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    haha, I don't have air.
  10. Grim-Reaper
    7,385
    Atlanta
    It will still be on the blower box somewhere. They get hot so they hang them in the airflow to keep them cool. My bet on a Non A/C cab is it will be right next to the blower motor so it get's in the airstream before the heater.
    There is TWO powersources for the blower. The highspeed has a fusable link and is tied in to the junction block on the fire wall near the brake booster. The low speeds are on a fuse in the fuse box.
