blower fan problem and question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by cajun72blazer, Nov 22, 2004.
  1. cajun72blazer
    cajun72blazer Registered Member
    May 5, 2003
    15
    Hey Guys, I need your help. I am not sure what part needs to be replaced or what need to be fixed, but here is the issue. When I turn the fan switch to first on position i can hear the blower fan bearly turning, second position blower fan turns fast enough tp push a little air out the vents, but not as fast it did last week, and the thrid position (Hi) the blower fan turns off. Is it the motor, switch, or speed resistor? Is there a way I can easly test each part?
    Thanks in advance for your help, Blake
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    damn, thats a tough one... It sounds like the switch to me... luckily each part is pretty cheap and if your driving a 72, they all need to be replaced. I tried to do what you are doing and just replace the one piece that was bad... but the new parts quickly make the older worn out parts go bad too.
  3. cajun72blazer
    May 5, 2003
    15
    Thanks for the hep. The problem was the A/C Blower relay.
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    damn I was hoping to see a weiland 8-71 or something:(
    lol
