blower motor fuse blowing
Discussion in 'The Garage' started by ColAdo82K5, Nov 26, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    OK, several months ago, my blower motor went out. No problem. Got one at AZ and put it in along with the fuse it blew. Well, I don't use it much, since my AC doesn't work, but now it is winter... so I was using the defrost to help melt/clear my windsheild from several inchs of ice and snow, it worked great for about 10 minutes, but then blew the fuse...
    NOW: It will instantly blow the fuse all the time, even when I disconnected the fan, the fuse will still blow.
    What other things are on the blower motor fuse that i should be looking at ? What wiring is most commonly at fault for this to occur ?
    Thanks,
    Blake
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I would check the wiring on the switch. The motor is not the issue if the fuze still blew when the motor was un-hooked
  3. ColAdo82K5
    Feb 18, 2000
    789
    MO
    For the hell of it, I but in a new relay for the blower motor. Same results.
    I'm assuming the wiring you speak of is that behind the HVAC controls in the dash.
    What other items are on that fuse ?
    Blake
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    check for wire chafing
    there is a resistor pack that controls the blower speed that may have shorted but it would be unlikely to get grounded (AC could be different then my non-AC)
    I am also fighting a high amp draw blower motor popping fuses lately
    could be the switch itself is toasted and grounding
    if it does it with blower disconnected then it aint the blower
