Blower motor relay?
Discussion in 'The Garage' started by mtrdrms, Nov 17, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    My blower fan works only on "HI". I have heard that I need to replace the relay. Where is it?
  2. mikras1
    mikras1 Registered Member
    Jul 25, 2003
    11
    CT
    You don't say what year your truck is - The relay should be mounted close to the blower housing, maybe even on the housing - passenger side of the engine compartment.
    But if Hi works, the relay is probably good because it is only activated for hi.
    My guess would be that the Medium2 resistor has gone bad, therby preventing Lo and M1 from working. The resistor pack is also located on the blower housing on the inside in the airflow. You can see where it is attached next to the relay.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Relay is good. Only operates on high. You need to look at your resistor block.
  4. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    I pulled out what I thought was the resistor and it was a couple of springs just hanging out inside the fan housing. So which one is the resistor? Can I remove easily from the fan housing? Oh and its an 87 PU without the C45 RPO and without AC
  5. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    If I'm reading that correctly, that thing you pulled out with the springs on it IS the resistor. I had to replace it on my 84, very weird looking creature, but thats what you need. Try a local auto parts store, but they probably won't have it. More than likely you'll have to go down to the Chevy dealership Parts Counter to get it. (Thats what I had to do)
    However, my blower woudln't work on any of the settings, after replacing the resistor everything works EXCEPT for High. Not really sure whats going on.
  6. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    anyone have a part number handy for this item and remember how much it cost? i'm thinking of just hitting up gmpartsdirect.com to save some money on it.
  7. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    you can also get them from LMC truck and Chevy Duty.
  8. poinzey
    poinzey 1/2 ton status
    Jun 16, 2004
    113
    Texas
    I had to do the same with mine last year to get the blower working again, But in my case it was a combination of bad wiring, relay, switch,.... I was able to get all the parts from my local O'Reiley's. They had to order the resistor, but it only took a day to get it.
  9. xpndbl3
    Jul 30, 2005
    510
    orland park, IL
    i found it at advance auto parts under part number RU67, thanks again guys.
  10. Bad Karma
    Bad Karma Registered Member
    Oct 28, 2001
    92
    Glendale,AZ
    My '77 Suburban had the exact same problem, turned out that the switch in the dash was burned up (literally...) :D
