Blower Motor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Sep 19, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    What is the HD Heater, and how do I know if I've got it? I'm dealing with a complete moron at Napa, and he basically refuses to sell me a new motor until I tell him whether or not I have this option.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. dyeager535
    26,978
    Heavy duty heater looks like this: http://www.dorianyeager.com/TablePics/delcoamfmtapecb.jpg is what your control unit will look like. Both the fan switch and defrost/vent switch have "off" positions, and the fan truly shuts off.
    Consider yourself lucky. Schucks counter person told me that that option was not in the computer, therefore it didn't exist. RPO is something like "C42"
    EXACTLY the same motor as an AC truck (probably all cars too)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I thought they all looked like that...prolly a default option for Canadian vehicles.
    Rene
  4. dyeager535
    26,978
    Even with the cooling hose on the motor? The motors wound differently, so the "high" on the HD/AC motor is about twice what "high" is on the non HD heater trucks. (which I assume is why they have a "cooling" hose for the motors)
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;http://www.dorianyeager.com/index2.html&lt;/a&gt;
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    mine didnt have the cooling hose but the replacement motor does. i wondered why they windowed the motor case now i know.
    by the way i just cut the resistor out so that low is now off on mine. cant figure why the fan must always spin ???
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    Interesting stuff..
    77chev: excellent idea on just cutting the resistor wire for "Low" to turn the fan off.. I was thinking about the best way to go about that, was thinking of wiring a hidden switch, etc.. sometimes I just think to hard..
    as for it spinning all the time it was some "feature" to keep fresh air in the cab at all times..
    where did you cut the wire?
    mike reeh
    77 K25
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I pretty sure that I don't have the heavy duty heater on my truck, and I'm glad, the one I got makes the truck feel like I am standing next to a blast furnace. I have been out hunting in the snow, and have had to turn the heater off because it was so darn hot in the cab.
  8. michaelm
    Feb 2, 2001
    872
    if you remove the little cardboard 3 connector item from the plenum in the engine compartment beside the fan motor you will see that chev used little unshielded pigtails of resistant wire. high is the connector that allows the power from the switch to feed the motor without passing through either resistor, medium uses the centre post and heats one resistor before the motor gets the power, low uses the post that will light up both resistor wires before the motor sees any power. i simply cut the pigtail resistor wire from between the low and medium posts. you cant see it unless you pull the part out of the plenum, i like 'invisible' mods.
    hope that made some sense. if you look at the above pics showing the fan motor you can see the connector i am talking about.<a target="_blank" href=http://www.dorianyeager.com/TablePics/heavydutyheater.jpg>http://www.dorianyeager.com/TablePics/heavydutyheater.jpg</a>
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Thanks!! That's what I needed[​IMG] Apparently parts guys are getting even dumber - The Napa computer doesn't even list a HD heater with A/C, only without - and it's the same P/N anyway (BK4551076 for anyone in need of a $ 17.99 replacement)
  10. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Hey! Let's be nice now. Not all us parts guys are dumb. Espicially us NAPA parts guys.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sorry 'bout that!! Must be a local thing[​IMG]
  12. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    You should try working with them!!!!!!!!!!!!!!!!!!!!!!!!!
    73 Vega 350SB TH350
  13. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    So where does that aux. cooling line go to? Can I mount one of those HD fans on a non-HD model? I need some more umpppf in the heater. It does feel like a blast furnace if your up against it but not in the back seat. I am looking for something to broadcast that air back there. I am also considering running some duct work to the rear.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    There's a little nipple on the plenum that it hooks to - I don't see any reason that the HD fan wouldn't work - just make sure to use the HD squirrel cage also.
  15. dyeager535
    26,978
    You could probably put a filter on the hole for the cooling port. The "squirrel cage" is no different HD or not. I tried using one off of an AC truck, they are way too "long" The AC/HD blower motor simply spins much faster.
    Dorian
