blower not working, but a/c is?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jshadwick, Jun 10, 2002.
  1. jshadwick
    jshadwick Registered Member
    Jun 24, 2001
    45
    Sacramento, CA
    Hi, just wonderin' if anyone knew what i have going on here:
    I was running my a/c in my '79 , on Max, when it decided to stop working. The funny thing to me is, I still get cold, air conditioned air, IF I am moving at near freeway speeds, as long as I dont have it on MAX; and it feels like the fan is on the low setting, not too powerful. When I come to a stop, the cold air stops. I am thinking something to do with the blower motor. I know little 'bout this stuff. Any suggestions?
    Thankin' y'all in advance
    james
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    The blower switches are notorious for going out...do you have any other speed? The switch goes to a relay
    out on the A/C box....you might check/replace that. Last but not least, theer is a "resistor" assembly that monts
    on the side of the A/C evaporator box. It's held on with 2 screws.....pop it out and take a look. It's just a
    couple of resistors that look just like coiled wire.
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the blower motor harness is found by the A/C box under the hood. check for a loose connection around the relay or the wires going to it.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Your blower is not working. Check the other replies for where the harness is and start checking connections before replacing it. When on MAX, the blower recirculates air from inside the cab. On NORM, it pulls in outside air. So, when you are going down the road on NORM, the air you are feeling is simply being "pushed" in from the outside without help of the blower. When you stop, it stops. If you switch to max and it closes the outside vent, the air probably stops as well.
  5. jshadwick
    Jun 24, 2001
    45
    Sacramento, CA
    yep, y'all hit da nail on the head. at least i have something, till I get around to workin' on it. get mighty warm here in Sacramento.
    thanks again
    james
