Blowing fuses in the 96***update 011804***
Discussion in '1992-Present Chevy & GMC models' started by Seventy4Blazer, Jan 5, 2004.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, i found a 15 amp fuse in the cig lighter slot. it controlls my PDL and lumbar compressor. i put a 20 amp fuse in it. it poped half a day later. then i tried a 25 amp fuse. it also poped. i wont go any higher, so i need to find the problem. do the relays go out a lot in this year?
    thanks.
    Grant
    found the problem, have yet to fix it cus im lazy.
    ended up being a pair of wires that have been chewn through by a small dog. not all the way, but enough to short out from time to time.
    Grant
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Blowing fuses in the 96
    power door locks and lumbar compressor ran off a cigarette lighter fuse?..stop putting the upped amperage fuses in..buy yourself what's called a "circuit tester" that goes in place of a fuse and beeps when a short is found.. then start unplugging power door lock actuators and the lumbar compressor, one at a time, to narrow down which circuit is blowing the fuse, then trace from there..
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i hate wires...
    ok, ill give it a shot. as for the fuses, yeah.. they are all labled funny. its the factory setup. it is a snow bird truck. all stock except for the air gate tailgate, exhaust, and PRISTINE maint. records.
    thanks for the info.
    hopefully i find it easy....
    Grant
  4. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    My 92 was doing the same thing. It was blowing the domelight and stereo fuse. It would blow before I could even completely get it in the slot! /forums/images/graemlins/eek.gif Evena 30 amp would blow that fast. I finally said [darn] it and took it to the mechanic. /forums/images/graemlins/ignore.gif
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I got the same issue in my 92, but it has been to cold to troubleshoot. What was the problem with your's?
  6. Blaze
    Aug 28, 2000
    3,285
    Raleigh, NC
    No idea. I finally got pissed and took it to the mechanic to be looked at. He;s had it since Monday and hasn't looked at it yet. If it isn't fixed by Saturday, I'm just gonna drive the POS like it is till it burns to the ground. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
