Blowing horn/acc. fuses?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Oct 28, 2001.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Everytime I plug any accesory into my cig. lighter my fuse blows. WTF?!??!?! I have checked the little wires and nothing has appeared to be cut. What do you guys think?
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
    "JEEP....SO GIRLY, BARBIE HAD TO HAVE IT"
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    mines the same way so i put in a 40 amp fuse an it works good
    when will you learn you needto drive a a chevy an pull fords out of the mud or over themsame as a jeep some one move that ford b 4 i go over it
  3. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    I know one time I knew somebody that had the same problem and it was stuff in the back of the lighter element . Think maybe you should replace it ??? If nothing else unplug the wires and see if the fuse blows over time ???
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Need to pick up a new lighter assembly - 90% of GM's develop this problem over time. Something in them gets loose and shorts out.
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> replace the lighter assembly or use a bigger fuse.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  6. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    if there IS a short and you put a bigger fuse in it, you have a very good chance of starting an electrical fire under your dash.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  7. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Exactly what was happening to me. Make sure the lighter is firmly attached to the ashtray. It has to ground out on the metal, otherwise you'll keep blowing fuses. If tightening doesn't work, replace it.
    Good luck,
    John
  8. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Tatman is right. A bigger fuse is not the right way to fix that problem. That cig. lighter and its wires were only designed to handle so much current...if you put a bigger fuse in there then a fire is a possibility. I've had to replace the lighter assembleys in 2 Blazers and my Monte Carlo daily driver...they wear out all the time. Cool thing is they're dirt cheap and easy to swap out.
    '73 K5
    Chevy good...Ford bad
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanx gang. I am just going to replace the sob..... went thru a whole box of fuses trying to trouble shoot.
