Blowing hot air
Discussion in '1983-2005 S-Series models' started by backyardbuilt, Jul 16, 2002.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I have a 98 sanoma are they like the older chevys that keep blowing air thru the vents even though it is turned off. And if I unplug the fan the a/c won't blow then right. Thanks in advance.
  2. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    i am not 100% sure but i would say that if you unplug your fan. you will not have functional AC the air your probably feeling is the fan in "off" state but static pressure in ductwork will actually kinda create a vacuum on the fan thus making the blades slowly turn and increasing in speed moving air into your cab. other then put it on the Floor setting "what i do , so it doesn't blow in my face" i think that would be the only Temp solution. sorry i am not more specific with this topic. hope it helps
    Ck1500
