Blown 14bff carrier? (pics)
Discussion in 'The Garage' started by midnitewarya, Dec 18, 2005.
  1. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    I'm almost done with my 14bff rebuild. I pulled off the diff cover and found these strange little metal pieces stuck to the magnet. I have no idea what they are and what they are supposed to do. Everything in the pumpkin looks fine, there is no grininding or clicking when I turn the pinion. Anyone know what these things are? It's a '98 14b 3/4 ton.
  2. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    Those pieces look like bearing cage.
    John
  3. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    If it is the cage, does it require a rebuild? Is it okay to run without it? How does this piece fail (what kind of driving caused it)? Sorry for so many questions. I'm just a little frustrated. My K5 has been parked for 4 months and I thought I was finally at the end of the tunnel.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yep looks to be a bearing cage(or whats left of one). You NEED to re-build it or atleast pull it out and see which bearing is gone and replace it.
  5. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    It definatly looks like a bearing cage, question is wich one. You definatly need to replace atleast one bearing. I would pull the carrier and check the carrier bearings for starters. Mark the preload spanners befor you back them off and count how many turns on each side you back them off. That way you can put it back and not change the backlash.
    If the carrier bearings are good than it is one of your two big pinion bearings, the small end pinion bearing doesn't use a cage like that so that rules it out.
  6. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    If you need to see a breakdown of the axle go over to pirate4x4.com and look at their 14 bolt tech article. I would suggest replacing all 5 of the bearings while you have it apart. The kit is only around $150 for BCA bearings. You will need access to a press for the bearings. Its not hard to do just requires some patience. Make sure you check the gears closely. Also check their pattern with some marking compound.
    John
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    More than likely it is the third pinion bearing. That is the only one that seems to grenade on its own and would also not provide any indication of a problem as it only supports the "nose" of the pinion. There are no rollers floating around in your dif?
    Ira
  8. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    Nope, no bearings rolling around inside, or any other cage pieces. I think it's from the 3rd pinion bearing. Thanks for all the help guys.
  9. 6.2puller
    Jul 8, 2004
    569
    New England
    the third pinion bearings I have installed have all been straight needle bearings and not roller bearings that have a cage like in the pic. If the inner pinion bearing went and the 3rd support bearings was good it would not feel bad spinning by hand. It would probably make a lot of noise on the road but your axle is not installed correct?
    I don't think it is the support bearing.
  10. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    No, it's not on yet. It was going to go on over Christmas weekend, but I think that will have to wait. It kind of works out for the better this way. It is a 4.10 and up front I have 4.56. So now I an excuse for the wife to let me get a new ring and pinion and bearings. :wink1:
    Al
  11. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    all the older axles used the rollers, then the change was in that bearing i think.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Looks just like the pieces that the pinion support bearing spit out on my 1974 14 bolt FF. :(
  13. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yep, definitely cage pieces, that is a very bad thing. Saw those in my wheel bearing one time, that truck was all over the road in a scary way.
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I can almost garuntee its the third pinion bearing. I've seen two come apart in the diff myself and one was in my DD crewcab. There was absolutely no indication anything was wrong untill I popped the cover for a routine fluid change. Luckily its a fairly easy repair.
