Blown Axle
Discussion in 'The Garage' started by LAXandBLAZERS, Jun 11, 2003.
  1. LAXandBLAZERS
    LAXandBLAZERS 1/2 ton status
    Jun 2, 2002
    100
    Durham North Carolina
    I think I messed up my rear axle the other day. It started making a banging noise on my way to work. I lifted it up and thought maybe just a U-Joint. I grabbed a hold of the driveshaft and it wiggled around the output shaft on the rear-end. I dont know what this is but the boys at work say pinon bearing ????? /forums/images/graemlins/1zhelp.gif But I am trying to sell it so I called all the junkyards trying to find an axle and fix it that way. No such luck. No rear 10 bolts and so I have a useless truck. What do yall think this is and how should I go about fixing it? Or should I just try and sell it as is? Please /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif (Sorry about the lenght)
    MIKE
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well if it is your pinion bearing you will be able to move the yoke (where the u-joint attaches). It is a pretty in-depth task to replace. Ask the guys at work if they know how. If it is just a stock 10 bolt some body on here should be able to hook ya up. If you were closer you could have mine.
    -brian
  3. LAXandBLAZERS
    Jun 2, 2002
    100
    Yeah nobody at work knows know and the olny shop that will work on it is the dealer. this sucks and Its going to drive me nuts. Thanks for the info. /forums/images/graemlins/k5.gif
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Check out local junk yards or any Members in your area might have one laying around. If you don't want the hassle of replacing the pinion bearing It is pretty easy to swap in a whole new axle browse throughthe for-sale forum for anybody in your area.
    -brian
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You 'called' the junkyard? ALWAYS just go, it is really hard to believe there are NO 10 bolts in that whole yard....
  6. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    4x4k20 has 3.08 10 bolts new for 300 here in Atlanta.
