BLOWN DIFFERENTIAL
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CORY CONWAY, Feb 10, 2002.
  1. CORY CONWAY
    CORY CONWAY Newbie
    Feb 10, 2002
    4
    CA< Rancho santa Margurita, 92688
    BAD NIGHT!! I LOST THE REAR END OF MY 1990 BLAZER AND WHEN WE TRIED TO MOVE IT ONTO A TOW TRUCK IT BLEW A 2" TEAR TYPE HOLE IN THE BOTTOM OF THE CASING. CAN THIS TEAR BE REPAIRED SO I WON'T HAVE TO REPLACE THE WHOLE CASING.
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Usually it can be reparied, my friend blew his differential and it was welded back together. You could always use this as an oppotunity and/or excuse to upgrade your axle to a beefier and stronger one, such as the 14bolt =) They are usually pretty cheap, but make sure its the same gear ratio as your front setup.
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
    6"Springs, Tranny, & Engine coming soon.
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    It'll be easier and cheaper to buy another complete rear end...
    assuming your truck is stock . If so it'll have the 10 bolt rear, dime a dozen diff. Check the For sale forum, there might be someone nearby with a good 10 bolt for sale for you.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Welcome to the site.
    Please take the time to fill out your profile. It helps us to help you.
    Do you have a caps key problem? Just curious as to why you are "shouting". [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Besides the cost factor you wont have any other suprises waiting for you, once you hit the trails again. Who knows what else was affected by a shear in the metal.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
    "JEEP....SO GIRLY, BARBIE HAD TO HAVE IT"
  6. CORY CONWAY
    CORY CONWAY Newbie
    Feb 10, 2002
    4
    Your right about both questions. Sorry about that.
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    Everybody does that...don't worry about it.
    Rene
  8. Can Can
    15,555
    146
    Cochrane, Alberta, Canada
    I NEVER DO, RENE.......ummmm..........oops[​IMG]!!!!
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  9. CORY CONWAY
    CORY CONWAY Newbie
    Feb 10, 2002
    4
    Thankyou for the advive.
  10. rain1971
    rain1971 Registered Member
    Feb 2, 2002
    50
    canada (7 hours from seattle washington)
    I would get a 12 bolt and go with a dual shock setup if you plan to have it last a bit longer than a 10bolt, best thing is a 12 bolt still has 6 bolt holes for the rims.
    the shocks will bolt to opposite sides of the housing, otherwise its a direct bolt in upgrade swap.
    it would be quicker and easier to just buy another used 10 bolt, then it will swap in with no fabricating whatsoever.
    I find replacing parts with their identical match makes the job go smootly and quickly.
    make sure you get the same gear ratio, or it will rip your transfer case up :)
    Theres no replacement for displacement!
    I want a big block!
