Blown ECM 1 fuse?
Discussion in 'The Garage' started by zcarczar, Mar 7, 2004.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Today I was out playing around in my truck and went to climb a fairly tall ledge, probably about 30" high and hit it a little to hard and blew the ECM 1 fuse, I then put another one in and went to try and cruise up the ledge and blew another fuse. I then put another one back in and backed off the ledge and havent blown a fuse since, but does anybody have a clue why this might be happening and what is all on the ECM 1 fuse circuit? I figure I have a short somewhere, but I need to know where to look first. /forums/images/graemlins/dunno.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    ECM-1 should be sending power to the Vehicle Speed Sensor through a Pink/Blk wire and to the A6 terminal on the ECM through another Pink/Blk wire.
    My guess would be the VSS wire got pinched on something underneath while you were doing your thang!
  3. zcarczar
    Feb 10, 2002
    2,495
    Hmmmm, would that cause the truck to die though? Cause it wouldnt start until I put the new fuse in.
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well with no power to your computer I could see that causing your truck not to start, there not just paper weights you know /forums/images/graemlins/rotfl.gif
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    once the fuse blows, the ECM has no power
  6. zcarczar
    Feb 10, 2002
    2,495
    duh! if I had just read your post a little better I would haven't of had to ask that last question. Ok, that makes sense now, wonder if I just jared the ECM from slamming into the ledge a little too hard with the frame or something. I geuss I will go on a wire hunt tommorrow looking for a short.
