blown heater core....help..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gabdam, May 18, 2001.
  1. gabdam
    gabdam Registered Member
    Jan 25, 2001
    26
    NEW YORK
    i drove my 86 jimmy today and smelled the sweet smell of anti-freeze, so i pulled over popped the hood everything was ok there but notice anti -freeze leaking out by my passenger door. i guess its safe to say my heater core is shot. the carpet is all wet and nasty. has anyone ever changed there own heater core and how difficult is it to do? i have'nt really taken a lok at it because it was dark. any help would be appreciated....how much does a new heater core cost?.................THANKS
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    It aint too hard.I pull my inner fender well to get better access to the bolts for the air box but I dont know if you have to. To me that was the worst part.But who cares about heat, just bypass it. Worry about it when it starts gettin cold :)
    All work and no beer makes Frizz a dull boy<P ID="edit"><FONT SIZE=-1>Edited by FRIZZLEFRY on 05/19/01 08:16 AM (server time).</FONT></P>
  3. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    One of the boys wrote a pretty detailed article on changing out your heater core. Check out the CK5 "technical" page- hit the trail map above and click on technical...............
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I changed the heater core on my 89 last summer It was pretty easy.It only took a couple of hours. I think it is similar to yours.
    1.Drain raidator&Disconnect heater hoses.
    2.Take off the heater case to firewall screws and nuts from the engine side of the firewall you also may have to take off your radio antenna if you have one.
    3. Remove glove box to gine a little more room.
    4.depending on how much room you have you may have to remove the ECM and right side kick pannel.
    5. Pull out the entire heater case. If there is not enough room take out the nut and bolt on the lower right side of the dash and lift up the dash a little.
    6. remove all the little screws and split the case apart. take out old heater core and replace.
  5. 85Blazernga
    85Blazernga Registered Member
    Mar 3, 2001
    44
    Georgia
    When I tried to replace my heater core in my 85, I found several little problems. First, the door that controls the air was in bad shape. The little clip on it was broke so the door wouldn't close. After I saw that, I went and got a junkyard box that had a good heater core. My question is, how do you split it apart? I couldn't get to the core on my new box. I took out all the little screws but it was still held by 'something'. I am thinking it was a rod for one of the doors. ANyone else have this problem?
    GSB
    Forever #3!!
  6. gabdam
    Jan 25, 2001
    26
    NEW YORK
    so the best way to get it out is from the outside of the truck not from behind the dash..how long should it take me?
  7. Grim-Reaper
    7,385
    Atlanta
    The bolts that hold the heater box in are under the hood. The Heater box is in the truck behind the glovebox.
    Here are instructions. http://grimsk5s.coloradok5.com/<P ID="edit"><FONT SIZE=-1>Edited by Grim-Reaper on 05/19/01 04:34 PM (server time).</FONT></P>
  8. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    took 3 hours hardest part was gettin the actual core out of the air box
  9. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Grim,
    Nice write-up. Perfect timing ... started smelling that stuff last week ... and didn't know about this!
    LMAO about all the stuuf you found in there!
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    To take apart the air-box itself becomes a chore if you miss the screws that are attached from the inside. Look closely at the foam ring around the backside of the box and you will find two or three holes that you can get a small socket or nut driver in to take out the bolts. They are very hidden, and will make you start looking for the BFH in desperation.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
