Blown motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Jan 25, 2003.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i blew my motor the other day, and i i have little money to put a new one in, i got laid off. if i were go to the junk yard and get a motor what would you suggest....its a 91 with TBI and its a 350..........i want to get a stock engine that will bolt up, and before it goes in i'm going to change all the gaskets and do a little head work..... /forums/images/graemlins/k5.gif
  2. unsane
    unsane Guest
    I would look for a VAN motor. Often you an get these cheaper than the truck motors, and they are the same thing. Then all you have to do is scrap the accessories from the van set-up and put your stuff on it. Plus alot of vans have not been driven as hard as trucks. my 2 cents
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    is it possible to just take the intake off of my motor and put it on an older 350 or 400? or any other small block? /forums/images/graemlins/pimp1.gif
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Most vans have 305s in my experience. Even most 3/4 ton vans. I've never spotted a 350 in a half ton van. I have found them in 3/4 tons. They're almost always in 1 ton vans and in 3/4 ton commercial vans. Van motors are often neglected beyond belief.
  5. unsane
    unsane Guest
    Right....Most vans I have seen have 350's! All junk yard motors are neglected beyond belief.
  6. unsane
    unsane Guest
    nope, not unless its an 86 or newer block.
  7. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    i couldn't use even put my intake manifold on it.....
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only difference is the angle of the 2 innermost bolt holes on each side for the intake. A bit of creative grinding can solve that problem. /forums/images/graemlins/cool.gif
  9. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Maybe in your part of the world most of them have 350s. However, if I were to count 305 vs 350 in any of the junkyards I've visited in Michigan the 305 count would outnumber the 350 count 3:1.
    Not all junkyard motors are neglected. Sure, they are once they get to the yard but believe it or not some of them are in relatively good shape. "Relatively good shape" to me is not requiring any machine work.
  10. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    you can do it ive done it already to save the money because the newer intakes cost more just waddle out the 4 middle bolt holes and it will fit i even called edelbrock just to make sure the ports line up easy job sould not take long
  11. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    check the want ad, we bought our motor (TBI out of an 89) for $400 - running with harness, you can find them cheaper than that too...or if you can find a rotating assembly and just put your heads and intake on....but if you're just looking, you'd want 87 and up for years cause of the 1 piece rear main seal and a motor with centerbolt heads (on the valve covers)
