Blown Rear-end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Nov 8, 2001.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    Upper Michigan
    Well, it turns out that the blazer isn't so super after all! :) The 1 year old 12-bolt let loose yesterday. Something punched a hole in the cover and it sounds like a tooth on the gear is missing. Richmond 4.10 Gears. I found a couple of 3/4 ton full floating rear ends a the local junk yard and the owner said I could have my pick of the best one!! I found a 14-bolt which I think is a pretty good axle. I also found another heavy duty axle but not sure what it is or what year chevy it came out of. It has 14-bolts and the rear cover is flat except where the ring gear is. CAN ANYONE HELP ME!!! Is there a web site I can go to that will show the different types of rear-ends?
  2. Leadfoot
    Nov 28, 2000
    Western Massachusetts
    click here
