BLOWN?
Discussion in 'The Garage' started by CHEVY 4WD, Aug 20, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I was wondering if a blower(supercharger) could help in off roading it dosent seem like there comanly used I no that there not cheap and you would probably need to cut your hood but dont they always make power not like a turbo and have lag and unlike nitrois you are always using it. BTW if im wrong about any of this please tell me im not a blower expert.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Superchargers are pretty cool, they work all the time, but the power gains are mainly noticable in the higher RPM range. A modest blower can help increase fuel economy if you keep your foot out of it, and if the engine is built for it they are quite reliable if you stay with a pretty modest one. I've considered doing a smaller blower, like a B&amp;M 144 or something, but wouldn't do it on a stock motor, I'd want to build it right with blower pistons and a cam that has a profile designed to be run with forced induction. So yes, they are a good mod unless all you do is rock crawling, since you'd never really get into the power. They would be cool in mud or on sand dunes. BUT, they are nto a bolt on mod, they take lots of planning and a correctly built engine to produce reliable power. A smaller one would fit under the hood of a Chevy truck, especially if you have a body lift.</font color>
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont know anything bout them either cept that when a camaro passes me with one it Whines and sounds bad ass,,,,, but anyway, What about mud getting in there? could you use a snorkel? or.........
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Mud in a blown motor would be just as bad as mud in a NA motor. Maybe I don't understand the question... /forums/images/icons/crazy.gif </font color>
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    what im saying is on a blown motor you have to have that Tunnel sticking out of your hood dont you? easier for mud to get in? or do you not have to have one of those
  6. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    There are several blowers on ebay most of the time. Eaton is very common. You still have to keep the air clean. A blower can be set up to produce some boost at or just off idle and is better than a turbo in that respect. It's up to whomever you know that can fab stuff up.
  7. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    If its the whine your after What about replacing the timing chain with a gear drive. Wont add any power but they do have a nice whine.
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    timing gears take away HP in the lower 4k RPM, from what i have been told. they take to much to turn.
    very accurate though.
    grant
  9. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    NOS does make a nitrous system that can be used at all times, I'm not sure what platforms they have designed it for though. It has a variable rate of flow, the harder you push the go pedal the more it throws. It can be adjustable up from 40 hp to 100hp for a factory stock motor. I have not heard how it performs in the rocks yet, but I hear that it is freakin' awsome in the mud and sand. Plus it can be hit for that extra passing power on the freeway. It's cheaper than building a forced induction motor /forums/images/icons/laugh.gif, and can be switched on and off. I think you need to be fuel injected so that it can trick your computer into running rich. If you have tbi you should be set to go.
  10. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    You are barking up a bad tree guy, turn around and leave! Ive had a few, and blowers and turbo's are the same in the aspect of CLEANLINESS. if you take in dirt grit, it stops working and if it fails, your pistons melt from not getting air. bad bad bad bad...same with a turbo.
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Just because you have a blower dosent meen you gotta have a L-88 hood with a big old scoop in it thats just for they drag racers that want areo dinamics and power
    AGIN CORRECT ME IF IM WRONG
  12. 1tonblazer93
    1tonblazer93 Registered Member
    Jul 16, 2002
    26
    cali vallejo
    hey 4x4r i have a 73 k5 with a blown 400 small block,you must upgrade your axles and drivlines.I run the b&amp;m 8-71 blower,my upgardes are pistons cam headers&lt;most importent is your ignition and wire's,the carb should be well prepped for a forced induction(cut of choke horns ,et),I run standar fuelie heads(if you go to BDS's web page they will also tell you that you wont need high dollar heads with a blower),I have 44'' boggers and detroits at both ends,I run the 4sp ( I hate slush boxes)when I need more power OR tire spin I just add a little throttle,I us this truck for pure evil and it has never failed me rather it's mowwin down small trees, mudd boggen,and camping down at the river with the soft gravel good luck on your selection /forums/images/icons/cool.gif my setup is now 3yrs old with only minor breakage,,driveline related
