blows a cloud of oil smoke when starting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Mar 22, 2002.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    my 89 tpi 350 blows a cloud of oil smoke when starting when it sits for a day,but not when it sits for more than 1 day or not when it sits for 2 hours or less.Supposedly the motor was a swapped by the dealer at 60,000 miles the truck has 140,000 on it now. Also when filling the oil it (valve cover) it drains very slow,it will only take 1/2 a quart before it will spill from the hole the I have to wait 3-4 minutes before pouring in more.also the oil pressure never goes over 45.
    also it dosen't blow any oil when driving.
    any ideas?
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    sounds like the valve stem seal to me.
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Sounds like a valve job to me... exactly what mine did. I however blew the engine so it wasn't an issue after that! DOH! /forums/images/icons/crazy.gif
  4. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    check the vaccuum modulator on the tranny. sounds stupid, but thats what happened to mine and it was a freshly rebuilt tranny and a brand new engine. i thought it was the holley pro-jection, so i took it off and slapped my carb on. it still did it. went to try another carb and noticed fluid on the backside of the carb. changed the vaccuum modulator as a friend suggested and it was gone. worth a try. its cheap and easy to change. good luck, tmanofcali
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Valve stem seal. Mine does the same thing.
  6. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Yup, sounds like the valve guides (seals) to me. That is what my '87 tbi 350 has been diagnosed with, but that is to be expected after 180,000 miles on the original motor (hell, it might even be the original oil! j/k)
  7. My 90' model does the same thing. I was told the same, valve stem seals.
  8. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    It IS the valve stem seals, but what a lot of folks don't realize is that these trucks came from the factory with the defect! I forget whether the seals were a poor fit or deteriorated very quickly, but it was a HUGE goof for GM. Many, many vehicles with 350's spanning a couple of years were affected at the time. This was fixed for the 1991 model year, however.
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    sounds like a chevy to me/forums/images/icons/smile.gif
    that puff has been pattented as chevy blue
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You actaully have TWO problems. One is that you most likely need to replace the valve stem seals. But the real clue is in the rest of your entry. You need to yank off a valve cover and determine why the oil is not draining through the head quickly. You should be able to pour oil into the filler as fast as it will come out of the bottle. The valve cover should not fill up with oil. Sounds like there is a bunch of sludge in the engine. /forums/images/icons/frown.gif
  11. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Valve stem seals, and like HarryH3 mentioned, something is clogging the holes in the heads to make the oil not drain properly. This could also have an effect on how badly the steam seals leak by the oil being pumped up faster then it can drain down and submerging your seals. Then it would really smoke! I am not absolutly sure about if it could happen or not, just an idea. Get in there and find out.
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you mean its not like that stock!?!?/forums/images/icons/crazy.gif
    mine blows smoke too, its just one of those things
  13. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    My 87 blows smoke just likt yours does...But I would lookin into the oil drainage thing a bit more...you don't wanna suck your pan dry cuz all the oil is stuck up in the heads...I'd yank the heads, and get a valve job, replace the seals and see if that helps...
    Chris
  14. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    My 87 burb does that as well and it only has 60,000 original miles on it. Its the valve seals.
