Blue smoke from one tailpipe on fresh engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarnivoreMan, Feb 8, 2006.
  1. CarnivoreMan
    CarnivoreMan Registered Member
    May 29, 2005
    46
    Ferndale, WA
    Hey all. I bought my 72 K5 from a guy with a supposedly fresh completely rebuilt engine in it.. like make 3k on it. I've had it for a few months but on drive it occasionally. About a month ago I fired her up and noticed its smoking a lot of blue out of one tailpipe. I think the passenger side. It seems to do it most on initial warmup, then subside. It will puff out more smoke though if I rev it all all.. :(
    Its got a 4 speed with a granny low so there's no funky vacuum crap is there?
    My brother said I may have cracked a ring if I over heated it. I was screaming through our field with it previous to the smoking problem. I think my temp guage isnt functioning properly as it didnt get very warm during that time, and it should have been toasty.
    Anyway, let me know if I left out some critical info.
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    i think blue smoke is oil being burnt? im not sure someone should be here to correct me
  3. CarnivoreMan
    May 29, 2005
    46
    Ferndale, WA
    Ya, blue is typically oil... I'm just hoping I dont have to do a complete teardown... but I'm worried I may :doah:
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Did you pull the plugs on that side to check color/deposits? How about a compression and leakdown test?
  5. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    also not a good idea to scream through fields on fresh motors. Tsk tsk!
  6. CarnivoreMan
    May 29, 2005
    46
    Ferndale, WA
    My brother and I went through the plugs and a few blackish with oil... I'll do a compression test next...
    And its not my fault! My buddy would get his priddy white rig in the mud if I did...
    I think next time I'll resist the peer pressure :rolleyes:
    Anyway, I'll see what I can find out and update the thread
  7. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    my 82 blazer had the exact same problem. It was a bad wire which caused the plug to fire sometimes and not at other times, so when it wouldn't fire, I guess the cylinder would fill with "stuff" and then when the plug fired it would burn it and come out the passenger side pipe...problem went away after I replaced the wires...cool.
