blue smoke
Discussion in 'The Garage' started by 1979jimmy350, Sep 1, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i know it is not a k 5 but my 1993 S-10 blazer blows blue smoke when i start it up but only after it has been sitting for a while. It does not do this when it is running what could this be ??
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Sounds like valve seals
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are these hard to change or am i going to have to take the heads off
  4. big jimmy 91
    Feb 21, 2004
    639
    They are a pain to replace , you will need a compressor and an adaptor to go in the spark plug to pressurize the cylinders one at a time so that you don't drop a valve
    You do not have to remove the heads to do this
    I have used the rope trick once and will never do that again /forums/images/graemlins/screwy.gif
    If you need a full explanation just let me know /forums/images/graemlins/thumb.gif
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    sure a full explanition would be nice
  6. big jimmy 91
    Feb 21, 2004
    639
    take out all the spark plugs
    take off valve covers
    use comp. air to hold the valves up one cyl. at a time with a spark plug adapter , get your valve springs off , remove and replace your valve seals , re-assemble the valve train ,do this to each cyl. until you have them all changed
    you will need a valve spring tool to get it done
    if I forgot anything I hope someone will add it in /forums/images/graemlins/thumb.gif
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    So would that be basically the same procedure in a 81 Z22 Nissan four banger? My run-around pickup is starting to run off of oil instead of gas. /forums/images/graemlins/grin.gif I'm getting about 250 miles to the quart. /forums/images/graemlins/histerical.gif
    Oh, and I'm afraid to ask, but what exactly would happen if a valve fell? /forums/images/graemlins/confused.gif
  8. big jimmy 91
    Feb 21, 2004
    639
    I'm not sure about a nissan , it might be the same , never touched one of them /forums/images/graemlins/dunno.gif
    Dropping a valve down the cyl. could result in removing the head to get it out /forums/images/graemlins/yikes.gif (never had that happen either)
    Hope that helps /forums/images/graemlins/thumb.gif
  9. jds_lpd
    jds_lpd Registered Member
    Jul 20, 2004
    5
    Lexington, Tennessee, United States
    When replaced them use the o-ring design and the unbrella design you will have double oil seal. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Leave it alone, Its fine I promise. It will just do it again in 35-40k miles. My 4.3 has done this for the last 250k miles. I've got 303k miles now. I burn prolly 1/8 quart of oil in 3000 miles. If it bothers you, fix'em. If not leave it be IMHO.
    John
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,085
    486
    Grand Rapids area
    [/ QUOTE ] That's probably bad rings.
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    That's not what I wanted you to say. /forums/images/graemlins/doah.gif
  13. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Try some "Lucas Motor Oil Treatment"--its pricey at 7 bucks a quart,but the stuff does work--one guy I know has an old toyota pickup he got for free because the previous owner forgot to fill it up with oil all the way after an oil change(his phone rang,he got sidetracked,and had a few beers while yakking on the phone)next thing he new the motor was making bad noises,then he remembered he forgot to put in the other 3 qts of oil!--it smoked pretty bad after that,so bad he couldnt drive it without getting tickets for excessive smoke,so he gave it to my friend when he heard he was going to scrap it.He runs 2to3 qts of lucas and the rest 20/w50 motor oil,it hardly smokes at all now,and he has driven it 15,000 miles already in the last year! /forums/images/graemlins/eek.gif
