Boat Engines
Discussion in 'The Garage' started by terrier72, Apr 12, 2006.
  1. terrier72
    terrier72 1/2 ton status
    Jul 6, 2004
    201
    Greenville, SC
    Not sure if this is the proper place to ask, but ill go ahead anyway. About how many hours will a boat motor go until it needs an overhaul? Assuming that it has had proper maintenance along the way. Also if you were purchasing a boat how many hours would be too many for you? Sorry if this is the wrong place to ask.
    THanks
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Need more info - 2 stroke/ 4 stroke, Inboard/Outboard, brand, salt/fresh water, etc...
  3. terrier72
    Jul 6, 2004
    201
    Greenville, SC
    Sorry it is a i/o mercruiser 4.3L V6 458 hrs only used in the fresh water.
  4. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    main thing is to run a compression test. make sure all cylanders are running close with each other.
    i would replace the impellar and water pump right away when you get it.
    ryoken is the man to chime in here.
  5. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    good motor... most gas inboards will give 1500 to 2000... I've got a customer with 2200 on his 350, pretty tired at this point... I've also seen V-8's with 1200 that are hurting...
    I do it daily, so any questions, just ask....
