Boatload of diesel part numbers (thanks all)
Discussion in '1982-Present GM Diesel' started by tRustyK5, Mar 10, 2004.
  1. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    OIL and FILTER
    oil filter, 2 qt best quality Baldwin # is B-7 fits '93 6.5TD
    1998 GM-8 turbo 12556124
    1993 waste gate actuator 10154619 $179.35
    FLWHEEL
    flywheel, 1 piece nonDMF 12556799
    pilot bearing 14061685
    bolts, flywheel 10085215
    ELECTRICAL
    starter, geared late model 10465054
    brace for geared starter 23502557
    glow AC11G 25168651 Auto Zone discontued
    glow AC 60G Glow Plugs 12563554
    starter hdwe 1982-88 6.2L Front Support Bracket 14028931
    starter hdwe 1989-99 6.2L/6.5L Front Support Bracket 23502557
    starter hdwe 1982-99 (all 6.2 and 6.5) Starter Bolts 15544950
    starter hdwe starter support bracket 14028931
    starter hdwe starter support bracket WITH bolts 15544950
    glow glow controller 12088520
    glow glow connector 12101871
    ENGINE BLOCK
    piston, 1999 6.5 19:1 12550059
    piston std 11550059
    piston .050mm over 12550062
    piston hi-limit 10236523
    piston, J-code from "std 1993 6.5 TD" 10236517
    pully, rubberized crank pully to reduce V belt wear 15592128
    Total Seal Piston rings 4474-00013-08 Summitt 353 800-230-3030
    TTY head bolts ES72724 Northern TTY head bolts (pn-ES72724) are $18.72 per head.
    gasket kit Fel-Pro 9701 PT Northern
    gear drive for camshaft Diesel Svcs Grp $220
    longblock 1998 GM L65 longblock assembly 12360010 #found on crate motor
    longblock 1998 GM L65 longblock assembly 12455592 3365
    INJECTION
    fuel sock in tank 25055272 $12.75
    injector 6.5 injectors...short "van" type 44 (part number unavailable)
    injection pump - marine DB2-4974 10191419
    injecton pump - '93 6.5 HD DB2-4911 10183901
    injection pump arctic H3 DB2831 4927 14098655
    injector, fine thread (M24 X 1.5) 10191419 Injectors (for 4974 marine pump)
    SERVICES and TOOLS
    tool M12-1.75 tap to clean head bolt holes
    Kent-Moore 1-800-328-6657 sells an "AMG Tach-N-TimeKit" part number J-33300-AMG for timing the DB2
    COOLING SYSTEM
    Radiator, 432285 (3/4T '92 Suburban 4-row) 432285 Auto Zone $300.00
    1998 dual thermostat housing PN 1255345
    Hi-Flow Waterpump serpentine 12534772 $96.00
    1998 water crossover housing 12553405 $68.00
    1982-93 diesel fan shroud
    Thermostat Housing, double 12553451 $24.00
    1998 hi-flow thermostats X2 12554977 $15.00
    Upper 97 radiator hose 15977350 $17.09
    GAUGES
    gauges by Isspro
    Auto Meter #2888 diesel tachometer 2888
    Auto Meter #6561 E.G.T. gauge(0-1600 deg. F) mounted in manifold before turbo
    Auto Meter #5244 3/16" stainless EGT probe w/install kit
    Auto Meter #3301 Turbo Boost gauge (boost/vac press 30 in. Hg.-Vac/20psi)
    LUBE
    stay-lube 3174 for CV joints
    Unless otherwise noted these are all GM numbers. Steve, if you get a chance can you have a read through and see if everything looks OK? I tried to clean it up a little, just want to make sure I didn't clobber it worse...:)
    Rene
  2. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    Re: Boatload of diesel part numbers (thanks Steve87K5)
    More part numbers care of "Don". (thanks!)
    These are for a 2002 Duramax.
    Engine oil filter/Wix # 57202
    Engine air filter/Wix # 46678
    Fuel filter/Wix # 33810
    Allison 1000 serie's M74 Transmission:
    Outer filter/Wix # 57701
    Inner filter available only through GM at this time/GM # 2953-7965
    Cab air filter/Wix # 24805
    Serpentine Belt, [note depend's on emission equipment installed on vehicle], available only at GM dealer's at this time GM # for mine at least is, 97300653
    there are variable's, the dealer need's the VIN of the rig to get proper serp belt. $45.95 with a discount applied.
    Transfer case oil GM prefer's their oil # 8800 12378508 1393 take's 2 quart's of this smelly stuff at $7.15 a qt. here in Spokane anyhow.
  3. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    This list has been edited for accuracy and clarity. If you have previously copied this list for your own use please have another look and note the changes.
    Thanks again to Steve. /forums/images/graemlins/waytogo.gif
    Rene
  4. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    Adding a link to the other diesel part numbers post...might as well have it all in one place.
    Click here for more part numbers
    Rene
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Just some more 2 quart filter part numbers
    ph373 fram
    sdf76 Amsoil
    FL308 Motorcraft
    PER84 Purolator
    PF832 AC DELCO
    M1-208 MOBIL1
    D801/D491 Deutsch, the 801 is 1.4 lbs and the 491 is .65
    K&N- HP 6002
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Found another 2 quart oil filter yesterday.
    NAPA 1794.
  7. FWP
    FWP CRS Premium Member
    Oct 11, 2000
    3,838
    Prescott Valley, AZ
    More
    Starter- Courtesy of Rene- I checked into it, the numbers are correct
    Bosch pn# is SR8574X, for the reman, and SR8574N for the brand new one. This is the gear reduction 28MT and after a search it looks like NAPA carries the Bosch line of rebuilt starters. My edit- Napa can also get new ones.
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,398
    PA
    Engine-to-bellhousing bolts: 3/8" x 16 coarse thread.
    A little over 3/4" of the bolt threads into the holes in the block, so add that to the thickness of a washer and the thickness of your bellhousing flange to get your required length.
  9. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,146
    Hollywierd, CA
    Doesn't work?
    ARB Head Studs for 6.2/6.5 1304062
    Valve Cover Set, Fel-Pro VS 50228 C (I think "C" is for cork)
    Oil Pan Set, Fel-Pro OS 34406
    Serpentine Belt Tensioner GM 89056038, ACDelco 38267
  10. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    Sorry, I think the link is dead since the forum upgrade. I'll have to look for the thread and post an updated link...or merge the threads.
    Rene
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Anyone have a part # for the PCV valve on an 88 6.2? I need the one with a little elbow in the pipe.
  12. tRustyK5
    Jul 23, 2000
    35,570
    586
    E-town baby!
    That's actually called a CDR valve on the 6.2's. PCV is gas engine crap...:p:
    No idear on a pn#, sorry.
    rene
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Can anybody tell me who makes the 1993 wastegate actuator, and if it's for a GM-3 turbo? Also, an idea on where to find it? Thanks.
    P.S. I have more part #'s that I will post when I get the chance, and I will try to get all this info in a downloadable Excel spreadsheet. :thumb:
  14. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,224
    Chandler, Arizona
    Prechamber part #'s
    I had to dig around, but I was able to find every (or at least most ) precup part #'s.
    Discontinued part #'s
    23500082 - 1 dot - 6.2L "C" code - 1982-1990
    14525518 - 3 dot - 6.2L "J" code and military - 1982-1990
    10149688 - 3 dot with a @ (circle A) - 6.2L "J" code and military - 1990-1992
    10163707 - 1 dot with a © (circle C) - 6.2L HD/Commercial - 1992 only
    Currently available part #'s
    10149630 - "T" - 6.5L "F" code - 1993-1994
    10230426 - Square - 6.5L "Y" code (and presumably military) NA - 1994-up
    10149629 - Circle - 6.5L "S" code - 1994-up
    10183926 - Diamond - 6.5" "F" code - 1997-up
    You will notice that there are some holes in the listings. For instance, what cup was used in 1991-1992 "C" code motors? Also, there is no mention of what cup was used in the 1995-1996 "F" code 6.5's, although I believe it was the "T" cup. If anyone can fill in the holes, please do.
    Also, the old "fuel economy" 6.2 cups are no longer available. I don't know this for sure, but I would bet the "Y" code 6.5 NA cup would give the best economy out of all the currently available parts (it has the smallest throat out of all the 6.5 cups). The "Diamond" cups are generally regarded as the best for maximum power in turbo apps.
  15. Camaronate
    Camaronate Registered Member
    Jun 24, 2007
    76
    Bastrop, TX
    These are not specific to the 6.2 diesel but may be useful for someone converting to the SM465 with hydraulic clutch.
    Clutch Shift Fork - 15592270
    Clutch Fork Pivot Ball - 15592268
    Hydraulic Hose - 15537760
    Flywheel - LUK part number LFW201
    Slave Cylinder - 15615868
    Master Cylinder - 15615867
    Clutch - LUK part number 04-087
    Nate
  16. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,153
    24
    Stevens Pass Highway, WA
    Engine block to Oil Cooler Hoses:
    Dorman Part # 265-154 and 265-155
