Boatsiding up to the door hinges
Discussion in 'The Garage' started by gotmud77, Jan 30, 2006.
  1. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I have searched and found different post but not really any pics to speak of. I found some that used the factory doors but none that moved the door sill up to the bottom of the factory hinges. Any pics would be great. Inside,outside what ever is available.
    Thanks,
  2. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    x2 any posts haven't showed clear pics. the only threads i found were supersize's and russ's but not much info!
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'd also like a very detailed report on boatsiding up as far as possible with pics
  4. gotmud77
    Aug 4, 2003
    689
    bellefonte
    There was also a user by the name wiesel? It looks like he isnot a member anymore. Maybe somebody has some pics of his k5.
  5. kram
    kram Registered Member
    May 29, 2005
    54
    Edison n.j.
    did the pic make it
    ts this it?
  6. kram
    May 29, 2005
    54
    Edison n.j.
    i think these are from ck5
    searched google
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    weisels got pics up in webshots . http://community.webshots.com/user/weisel_77
    Hes a good guy , shows up to wheel when he can .
    Look at the last pic in his fab folder , he moved the lower hinge up after he cut it off .
    I got to go take some pics , was cutting on mine an hour ago . Not going too high , just to the bottom of the lower hinge . Damn wifey gets her way , she wants half doors for her days out LOL
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Eli (wiesel) has his up to the middle of the lower hinge and made his doors fit. I cut mine up to the same spot and made my doors fit too. I don't have anypics of my doors though.
  9. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    That's funny, I've been researching this very thing and just recently PM'd this guy asking for some close-up shots, though this isn't technically boatsiding.
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yep, that's my red and black POS. I'll try to get a few close-up pictures of what I did with the rockers.
    As mentioned in my previous post, if you go up any higher you will have to start modifying the lower door hinge and then you will start having an issue with being able to lower the window all of the way. Originally the doors had power windows and the bottom corner of the window motor/regulator was just starting to hang out the bottom, but I had plans to convert to manual which gives a little more room.
    There is around 5" cut off the bottom of the doors for reference.
    I chose to go this route because I wanted the rockers raised, and I wanted to be able to use the 3x3 tubing as a slider to help protect the sides of the body. On a lot of rocker/slider installs if you keep the tubing in far enough that the complete door still closes then the tube does not stick out far enough to protect the sides, you would probably have at least 3" of fragile body panels that stuck out further than the slider.
  11. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Most of the Zonies around here run high skids so that doors are no longer an option... Some examples:
    Marv
  12. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    hey marv i notice the boatside pics are not plated. wouldn't a smooth plate be less likely to hang up on rocks than the attachment tubes exposed?
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yep... In fact most of these trucks still have big "sight holes" in the floor...:haha:
    A smooth plate across the bottom would be a good idea... but usually, you just slide along the outer edge of the [==] tube... or the frame and crossmember hangs you before those tubes do...
    Marv
