Bob the rear or stretch the wheelbase?
Discussion in 'The Garage' started by Sandman, May 8, 2003.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I cant decide if it would be better to bob the rear to the rear spring mounts or to just move the axle back 8 or 10 inches. Either way I want to get rid of the overhang and there are pros and cons to each one. Any thoughts?
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I think it would be better to bob the rear. Because as you lengthen wheel base, it gets easier to high center on obstacles and whatnot. And from some of the pictures i've seen of your truck you've gotten pretty darn close! if not actaully getting high centered. So my vote goes to bob the rear. You wouldnt really get much out of longer wheel base, bigger turning radius, but who wants taht? Only advantage would be, say, mud holes, and SOME obstacles. But cons outweigh pros i'd say for longer wheel base.
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    I'd stretch the wheeelbase that way you could still put your top on and still have some "utility" out of it. bobbing it is a big step I think if your gonna go that route you should put a pickup cab on it and a short flat bed and sell that nice blazer body /forums/images/graemlins/truck.gif
  4. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    BOB!!!!!!!!!!!!!!!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Bob it. If you stretch the wheel base the wheel looks wrong in the wheel opening /forums/images/graemlins/grin.gif
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Here is a pic of mine. It is stretched about 6 1/2 inches.
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Bob's yer uncle,spot on and all that.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    bob it
  9. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Do both. Cut a little out of the back, then relocate the extra.
    Or just go 4 link and hang the sucker out there by itself /forums/images/graemlins/grin.gif
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    That might be what I do. If I do bob the rear, The tailgate section will just move forward so I can still run one. I also have a softtop so I could just shorten it up and make it work out. Moving the axle back a few inches would be pretty easy also. I could just cut the back of the wheel well some to make it still look OK.
    The biggest problem I had at moab was dragging the rear on every steep climb. /forums/images/graemlins/tongue.gif
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    How did you move your axle back? Thanks.
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I knew it. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. Kyle89K5
    2,273
    OKLAHOMA
    Ask some of the guys around here what my gas tank looks like /forums/images/graemlins/frown.gif
    I think if you try and go extreme one way or the other, then you run into complications. It's sorta like going with a bigger lift. The more you do, the more stuff you've got to fix. Doing a little of both and meeting in the middle would be alot easier IMO.
  14. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ...it was really easy. I am running Ford 57's and they have a big offset from the front and rear to the centerpins, so I just mounted them backwards! They flex like no other, and I have experienced no axlewrap w/ them being backwards. I want to bob mine too, but have to work something out w/ the fuel tank and stuff first.
    The tires still stuff up into the rear fenderwells nicely, and mine arent trimmed that much in the back.
  15. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    go 4-link + coilover and bob the bed all the way to where the tires are. 90 departure angle. /forums/images/graemlins/grin.gif
    j
  16. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    BOB IT. For some reason I'm a big fan of the bobbed k5's. (see webshots) /forums/images/graemlins/grin.gif
  17. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks for the info. Looks like a good cheap way to do it. I think thats what I'll do. /forums/images/graemlins/thumb.gif
    I would like to go coils in the rear but with the work involved, It'l be a future project.
