Body bolt torque spec..my bushings moving around on me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Nov 14, 2001.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I cant find it. Can anyone tell me what the factory torque spec is for the front body bolts? Would it be different with poly bushings. Mine seem to be moving around on me...
    Brent
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I did about 55lbs to 60lbs...forgot. But I would say it is from 50 to 60lbs
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    If I can remember the instruction sheet that came with some Energy Suspension mounts I got once, it said to torque them to 85 ft. lbs.
    But don't take my word for that. I suffer from Alzheimers disease!!! [​IMG] [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. Boss
    2,550
    Maryland
    Personally, I think that is a bit too tight [​IMG]. The Poly bushings starts to bulge and you don't want that.
    Boss
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I just called energy suspension and they said, just go to factory torque specs. They said it is no different for the rubber or poly. hope that helps a little, I dont know the factory specs though[​IMG]
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Wow, you called them!!! Thanks homie!! I appreciate the help!
    I think the fact I put grease on them is why they are shifting. I for some reason thought all poly bushings needed to be greased..not these obviously!
    Brent
