Body Bushing
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by therobzilla, Dec 4, 2001.
  1. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    OK here is the question,
    I am going to replace my body bushings with either Daystar or Energy Suspension. My Blazer 72, is going to need new body bolts for the bushings, after I get them removed, I would be suprised if any survive the Cuttoff Wheel, pretty rusted.
    I thought I read a post some time ago, regarding the replacement bolt sizes and amounts needed. I searched the archives but to no avail??
    Does anyone know the replacement bolt sizes and or a souce to purchase them. I have tried with LMC, and all the others, the only company that I can find with bolts is LMC and they want too sell the complete kit with bushings, I don't have a problem with purchasing the whole kit, the problem is that LMC only sell the bolt with the original factory rubber bushing, and I want the ureathene bushsing.
    Any leads would be greatly appreciated.
    Thanks in advance.
    Robzilla
    therobzilla@hotmail.com
    <P ID="edit"><FONT class="small">Edited by therobzilla on 12/04/01 12:13 AM.</FONT></P>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't know who posted this info previously or I would give credit where it is due.
    Radiator Support: 7/16"-13 x 3.375" carriage bolt
    Body Mount #1: 9/16"-12 x 6" hex head cap screw
    Body Mount #2: 3/8"- 16 x 10" Carriage bolt
    Body Mount #3: 3/8"- 16 x 5.5" Carriage Bolt
    Body Mount #4: 3/8"- 16 x 4.5" Carriage bolt
    Body Mount #5: 3/8"- 16 x 5.5" Carriage bolt
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Steve Chin originally posted these body mount bolt spec's on the old blazer-net message board as well as here.
  4. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Triaged,
    Are these bolts for the 1st gen models?
    Rob
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Yes. I already bought all of those sizes but haven't finished all the body mounts yet.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    OK dumb question probably but informative, body bushings? when you do a body lift do these get replaced? and if I do a 2" body lift how many troubles am I going to have to deal with? Also should I replace my floor pans, etc. first or replace the body bushings first?
    Like em big and topless
    Excuse me...Would you mind removing your import from under my chevy?
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    LKJR,
    i put in a 2" body lift in mine. you don't have to replace your bushings unless they are worn out or gone, mine were. I had to make adjustments to the colum shifter linkage. You will also have to move the bumpers up, the front does not look bad, it's the rear that may need a face lift. not sure about the floor pan...
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
