Body Bushings ??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JeffDJimmy, Jul 29, 2001.
  1. JeffDJimmy
    JeffDJimmy Newbie
    Jul 29, 2001
    3
    Just installed the LMC body bushing kit. In all my manuals I cannot find any torque specs or tightening procedure. How do you tighten the body bushings?
    After the body bushings installed, the right hand door does not align correctly. I put the same spacers as the old bushings but the door is tighter at the bottom and open at the top on the rear edge. Any ideas?
    Any comments much appreciated!
  2. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    Try putting more spacers on the mount closest to the rear of the door on that side. When I put the 3" body lift and new bushings (from LMC) under my truck, I had to use quite a few spacers to get the doors to line up properly. And I don't believe there were any spacers on the truck when I removed the body from the frame.
    I just torqued the nuts until they were pretty tight. The spacers in between the bushings seem to serve as a gauge for how tight you should make them (when you hit the spacer, you can't really tighten them anymore).
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    From the FSM: Body mounts (all except for the ones in the driver's compartment floorboard) 20 lbs.*ft. The big ones at the driver's compartment floorboard should be at 50 lbs.*ft.
  4. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    Did you buy the poly bushing or the rubber ones.
    How long did it take to get them. I am in need of some.
    How much of a pain was it to replace them.
    Blazin72
    Blazin 72
  5. JeffDJimmy
    JeffDJimmy Newbie
    Jul 29, 2001
    3
    I bought the complete kit from LMC, standard rubber.
    It took me about 10 hours after I got the rear bumper off. Three hours were spent on one rusted bolt on the passenger's floorboard. A cut off wheel and high speed die grinder saved the day. It went better than I had expected.
