"body exhaust cut outs"?
Discussion in 'The Garage' started by Xtremjeepn, Jan 22, 2007.
  1. Xtremjeepn
    Xtremjeepn 1/2 ton status
    Jan 17, 2006
    437
    Saddle Rock, CO
    Not really sure what to call these. I have seen several cars/trucks over the years where the exhaust exits out the side of the car through a cut out.
    Thinking something like this might be kinda cool on the side of the truck. http://www.stylinconcepts.com/part.aspx?partid=15324
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Til you blacken the side of your vehicle... :rolleyes: Ive only seen them exit before rear wheels and they usually are apart of a body kit. I own a late model mustang with som mods and have seen quite o few side exhausts. The issue is the 90 degree and sometimes 180 degree (yes pipe turns and goes to front of vehicle:doah: ) required to do this is not a good way to make HP. Might as well run side pipes or better yet go twin 4-5 inch stacks!!! :bow:
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    problem with most Chevy's is that the frames almost always hang lower than the body. means you have to go below the frame to do that. So from the side you see the exhaust below the frame then out the body. Not so good looking.
  4. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    exhaust cut outs
    I don't think it looks gay at all.
    (not that there's anything wrong with looking gay)
    Just kidding dude, I've thought about it too, but I don't think there's any real good way to do it.
    Between rock rash and the low hanging frame I think you shoot'em straight out the back. Maybe thru a custom bumper.
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You could always cut a hole in the frame I suppose :whistle:
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    its been done. Brook Green did that on the Freak. Sweet setup really.
  7. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    hole in the frame is no biggie, box it on the backside...
    i plan to run long tubes or custom builts that come out through the fenders...
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I too have thought about it.... would a body lift of some sort provide clearance enough for the exhaust to fit between the body and the frame or would that not be a good idea?
