body expanding
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tarheel, Jul 30, 2003.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    my "73 k5 has a very noticeable gap between the tailgate and the body on the drivers side. kinda hard to explain, but seems like the weight of the hard top has caused the bed panels to spread over the years. the problem is so bad that the tailgate latch on that side barely engages the bracket even with the shims that the p/o installed as a half-ass fix. anybody familiar with this or know how to fix it? /forums/images/graemlins/ears.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Uhhh the problem isn't the top. It has proably helped keep it from folding worse. The problem is your rusted out tail pan (the part the tail gate bolts too). Stand behind the truck and look at the tail pan. If it's frowning it's probably rusted out.
  3. dyeager535
    26,979
    How is the gap on the other side? SOUNDS like a "simple" alignment is in order (of the panel) but if the gap is "normal" on one side, (both in width and even from top to bottom) but excessive on the other, I have no further ideas.
  4. DetroitK5
    DetroitK5 Registered Member
    Apr 21, 2003
    7
    Wow - I've got the same problem never knew what was causing that. I'm gonna check that out.
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    yep I had this problem along time ago. I thought the same thing and then started looking at what supports everything and found a cakced tailpan.
  6. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    mine's like that too. Just used a come-a-long and winched it back. Now I'm going to go get a better look at what the real problem is
  7. DetroitK5
    Apr 21, 2003
    7
    How exactly did you winch it back in place... Attach one side to a tree and the other to the side that's out of alignment?
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I winched mine together too.
    I used a hand winch, hooked it into the the two latches, and pulled them back together.
    My tailgate had popped-up from wheeling. Even when the top was on. Now that it is off (most of the time), it's worse. I made an angle-iron going across the two sides and bolted it in to hold the two sides together. This worked for the trails, but made carrying cargo a pain.
    Luckily for me, I found a rear rollbar. A front should work too with some mods. The rear bolts into the body pan, and I will make some tabs on the sides on the bed rail overhang, and bolt it on there.
    Good luck.
    BTW: My rear tail-pan is rusted right near the tailgate hinge bolts. The bottom, and the body mounts all look (surprisingly) good.
  9. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    those little 10$ ratchet tie downs work wonders
