body filler
Discussion in 'The Body Shop' started by big83chevy4x4, May 13, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what is the maximum thickness for body filler with out it cracking?
    what brand is the best?
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    1/4" is the thickest without shinkage...
    I use Rage...
    Easy to work with...easy to sand... /forums/images/graemlins/thumb.gif
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    On the shows on TV where they've done this they always say if you have to put more than 1/8 inch on then you should really do metalwork first.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I've bought a few vehicles in MN where they just stuck something into the rust holes and started filling with bondo... Looks good for about 3-6 months before it starts to come apart again /forums/images/graemlins/doah.gif
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    bondo with fiberglass in it works well. Not the easiest to sand, but it doesnt shrink much at all. Makes everything you bondo pretty darn strong too.
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Fiberglass reinforced Bondo is how I repaired the 15"x12" hole in the floor of my Heep. I used a piece of sheetmetal and laid it down on top of the hole then slopped Bondo all over it and anchored it with sheet metal screws. It looks like crap but it was a good solid fix. /forums/images/graemlins/thumb.gif
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I didnt know it was *THAT* strong. /forums/images/graemlins/bow.gif
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    as others mentioned the fiberglass reinforced filler is good stuff for "thicker" applications. always best to skimcoat over that with regular mud, little more primer friendly. also the glass reinforced stuff should always be used over patch panel seams. that is an area prone to cracking.
    also keep in mind that fillers have come a long way these days and a quality filler is likely not to crack even when relatively thick. but yes, metalwork when possible...
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i plan on going as much metal work as posible but just wanted an idea on how think i could actually go with it and not have a problem
