body lean
Discussion in 'The Garage' started by August, Dec 15, 2006.
  1. August
    August Registered Member
    Nov 27, 2005
    20
    Spain
    Hello,
    My 1980 GMC Jimmy has a little body lean on the passengers side, near a inch. Is it normal? Could be a bad leaf spring? Do I have to put new ones?
    Can be repaired?
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Could be suspension, yes, or could be body mounts.
    First check tire pressure :) ... then measure from the frame to the ground. If it's the same side-to-side, measure from the body to the ground. This would mean you need new body mounts or something.
    If the frame measurements differ, then I would take the springs off, make sure no leaves are broken, and switch them side-to-side. This might cure it :)
    -- A
