body lift and e- brake cable
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Apr 4, 2002.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    just put on the body lift and the e- brake cable ( usually hidden by inner fender) on the drivers side is TIGHT. has anybody else ran into this? any suggestions? Thanks
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Didn't have any problems with mine. But there is an adjustment screw on the I believe it is usually on the drive side towards the rear tire. Should be a long threaded rod with a but holding the cable if I am not mistaken.
  3. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    mine is, real bad, I should due sumpin about that?
  4. xplosuv
    Mar 9, 2001
    515
    Sacramento, CA
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I fixed the problem by moving it to the other side of the body mount.
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    i'll give that a shot...i tried to loosen it up under the truck but the only thing that happened was my e-brake cable got loose...nothing else...thanks
  7. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    With a rear disc conversion and 4" suspension lift my ebrake was 5" too short. Called Control Cable in Sante Fe Springs, CA. They did a 24 hour turnaround made me custom cables for $35 each.
