body lift and speedo cables?
Discussion in 'The Garage' started by MUD JUNKIE, Apr 28, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    when I bought my truck it allready had a body lift on it(3")
    the speedo is'nt connected and I put 2 and 2 together.
    since the body lift raised the body,is the cable too short now? I need a new one sice the connector is broken,but I dont wanna buy another cable then have it be too short,so what can i do?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    nope...there should be plenty of slack in the cable for a body lift. get under the t-case and check it out.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    PO had installed a 3" bodylift on my '87. Speedo was (and still is...) hooked up with what appears to be the stock cable. Granted, it's a bit tight, but not so bad that it would need to be disconnected.
    Maybe some "shady activity" would explain the speedo cable being disconnected, since the odometer doesn't work without it...
  4. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    yes thanks for the info I will pickup a new cable tonight.
    the oddometer quit working at like 240,000 miles /forums/images/graemlins/eek.gifand its on a different motor,it used to be a 250 v6
