body lift = body/frame flex?
Discussion in 'The Garage' started by muddybuddy, Apr 3, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    here are some pics from last weekend. the truck on the left is mine (k30 6" susp 3" body) and the right is andrew's aka protechk5 (k30 stock) if you look at both bodies, mine flexes a ton more, why? is it because of the body lift or what? the frame has no visible damage to it or anything. im already going to take the body lift off this weekend, is there anything else i can do to get rid of that frame/body flex? im thinkin bout maybe boxing the frame or something, but its already the k30 frame, i wouldnt think it would really be necessary. thanks for your help
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    are the trucks lifted in the same way? if you have stiffer springs, you'd experience more of an issue than your buddy, i'd think.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    his k30 is completely stock, mine has 6" susp (stock rear springs with 6" block YIKES) and 3" body lift on it currently.
  4. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    My question is why don't you want frame flex?
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    doesnt it weaken the frame? dont people box the frame to strengthen it and to limit frame flex? i dont see how frame flex is a positive:confused:
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    agreed - i don't think it's positive either. that being said, a 6" front lift spring is going to be quite stiff - unless you paid BIG bux for an outstanding front lift spring. i bet that's your problem. what brand springs are they? i've got 4" procomps up front, and they aren't impressive in flex, but not terrible.
  7. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i would think that yours will flex more becasue of the taller suspension, if both of you are going up a simlar object it is x distance to his frame and its x+ your suspension difference to yours, so you are bot applying a simlar load at different distances. Its like putting a cheater bar on a ratchet you get more results with less force. This is just my guess it could be other things also
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i bought the truck with all that lift crap on it. i think the springs are skyjackers. ive got some TC 52's im going to be swappin up front and shackle flip and TC springs for the rear, and removing the body lift.
    so you think stiff front susp is the culprit?
  9. bigbluesuburban
    Feb 8, 2006
    1,362
    Well I am not going to stick my neck out on this one. But I will say that I don't think the flex you are talking about is really a problem. Just pay attention to your frame and if you see a crack forming... fix it.
    I personally like the flex in my frame, it's where I get a great deal of my suspension travel.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i really don't think frames are designed to flex - certainly not much. at some point i'd think it's going to fatigue. if you need to flex, a stellar suspension flex is definitely going to be better. i think suspension flex would also provide better traction.
    i don't think there's a lever mechanism going on due to the suspension height, as the force of the weight is directed downward, not sideways.
  11. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Well, I definitely don't agree that his frame flex is healthy or good. I'm concerned about it on my rig. I don't want that crap. I have a 1/2 ton frame and want NO FRAME FLEX! What is the proper way to box this thing up so that it is stoudt all the way around and not in places where new weak points would be created?
    Manny
  12. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i dunno what to think about frame flex....i know it seems bad especially for a 1/2 ton..i know this has nothing to do with our trucks but if you walk up to a tractor trailer its all c channel and they have to use that because they need the frame to twist to get going....i just wonder if the same rule is applied in this instance...oh btw thats the only thing i ever learned on trucks the tv show...
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea i dont want frame flex at all, id rather pull a tire off the ground instead of flexing the frame
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    twoslow - your example may or may not be applicable. it depends on the properties of the metal used for the frame. i'd suspect that in such a case as you describe, a steel with a high modulus of elasticity (a great ability to deform and come back to the original shape) would be used in such an application. this would probably make it a very expensive metal. in our trucks, i'd suspect that they don't make them on account of having a frame flex much. they were probably built to withstand only the frame flex given by hauling a load or supporting a load, however the idea would be to get it all into the suspension (they wouldn't design a frame to deform under the carrying capacity of the truck's bed - that's just dumb, thus the springs). so, i'd suspect that the engineers did not require a metal with a high capacity for deformation that comes back to it's original shape. i still vote that frame flex is bad.
    manny - a kick-ass cage welded to the frame would help! :D
    muddy buddy - i doubt your body lift is affecting your frame flex. i still vote the front lift springs as the culprit.
  15. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    CS,
    It's included in Phase II of my build-up scheduled to begin in July/August. Stay tuned for further details! :D
    Manny
  16. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    That is frame flex bud, every longbed truck Ive seen had some degree of flex like that but yours is pretty extensive.. Check over that frame and make sure its all good...
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i know, what really has me worried is that protechk5's k30 right next to mine has barely any frame flex:confused: so i should probably box the frame then. i guess ill have my friend with a welder do it in may when we are back from school.
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'd really consider those front springs. you could probably get away with alot less frame flex if you had softer springs up front. if you box the frame and get rid of the flex, you'd better hope that your rear springs got plenty of flex to keep the tires on teh ground.
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to be running TC 52's up front and shackleflip with johnny joints in the rear, so i should be able to plex a good bit w/o the frame:D
  20. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, i doubt you'll have much of an issue w/ the frame flex after that. :) wait on boxing the frame till you do that - you may not have much frame flex after that. :)
