body lift:bolt sizes:differant?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Jul 3, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Just got a 2 inch body lift, about to install. I think I know where each goes, or at least it will work. But, the Performance Accessories lift has 4 of a little longer length than the other 6. Any know where the longer ones are SUPPOSED to go?
    Ken H.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    The longer ones go in the last 2 positions. When I did the ORD body lift the longest bolts when in the very rear of the K5.
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    what I did when I installed my ORD lift and plan to do this weekend, is to split the set of bolts in half so you have two identical sets of bolts (one for each side). Then, go remove all the bolts from one side of your rig marking which position each one came from. You should easily be able to match up the different length bolts with the proper placement that way.
