body lift installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grk76, Jun 27, 2001.
  1. grk76
    grk76 Registered Member
    Jun 27, 2001
    20
    NC
    Anybody ever installed a 3" body lift on a 2wd '77. I have all of the parts but no directions. Any suggestions?
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    There should be no major differences between 2 or 4wd....there are a lot of post in the 4wd section concerning body lifts. You pretty much have to loosen the bolts that hold the body on.....jack up the body, usually one end at a time, insert the lift pucks, install longer bolts. Your fan will probly hit the bottom of the shroud. If it's an automatic the shift linkage, outside the firewall, will have to be legthened. Watch the emergency brake cables etc. That's about all I know of. Check the 4wd area for more tips.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Look up Espen88 in here he has a wholewrite up with pics on how to install a 3" body lift .
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
