Body lift installed and I like it
Discussion in 'The Garage' started by weisel, Nov 20, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I got home with my new body lift kit and just had to go to work on the truck
    imidiatly because I couldn't sit idle with brand new parts waiting to install.
    I fired up the air compressor and in no time it was installed and I was loving
    it. Instructions were a little generalized but who needs instructions
    anyways, huh? Had to cut out some of the old bolts, but non the less an
    easy instal. I thought it would be more difficult to get all the stuff
    relocated/adjusted (fan shroud, tranny linkage, wireing, ect.) Well now
    I want to get my 35s mounted and start hacking at the fenders. I just
    wanted to express my happyness. Thanks again Marv for selling me the kit.
  2. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Pics! Pics! Pics!
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    1, 2 or 3 inches?
    What did you do for the steering shaft? Bumpers?
    Let's see some pics.
    -- Mike
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Ok, I'll take some pics when I get home today. It was a 2" lift. For the sterring shaft, I just
    removed the plastic junk "gluing" the outer shaft to the inner shaft, drilled a hole in the
    inner shaft where I wanted it, and used a cotter pin to hold them in place. I'll show a pic
    of this too. I left the bumpers in place since they arn't original anyways. Might modify the
    rear to be sunk inside the frame rails soon. I also drilled a hole in the frame so I could move
    the tailgate spring catches up to accomidate for their new position. The tranny linkage was
    modified by just cutting it in half, and welding in a short peice to extend it.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You should really use replacement plastic pieces as they are made for easy crush in the event of a head on collision to colapse the shafts within themselves lessening the chance of the steering wheel going through your chest.
  6. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    would a plastic pin work? Where would I get a replacement?
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah a plastic pin will work, you can get them at napa.
  8. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    In Reply to:
    "...colapse the shafts within themselves lessening the chance of the steering wheel going through your chest."
    Jeff, you really have a way with words. You convinced me.
    ____________
  9. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Here is the link to my pics
    my pics
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Looking good /forums/images/graemlins/thumb.gif
  11. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ool sounds cool...man i wish it was that simple out here..you do that to a body out here and you have to torch half of it! lol.. /forums/images/graemlins/crazy.gif /forums/images/graemlins/tongue.gif
  12. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    The front eight bolts were easy as heck to take out. Only took about 15 min. But the two by the tailgait, took over an hour a peice to cut out. Other than two of the bolts supplied by the kit were too short, it was easy to install. Thanks for the compliments.
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Nice body lift, I left my fan shroud connected at the top and bottom and added a spacer in the middle
    My machined blocks
    The body lift made a good amount of difference in the ride (I also added poly bushings).
    Later, J
  14. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Looking good. I didn't think of extending the shroud. what size lift is yours? Are those steel blocks?
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    The blocks where 1 1/8" and the poly bushings added about an 1 1/4" over the worn out rubber bushings.
    Yes they are! I never thought I would like the plastic/resin lift pucks. If I remember right they are hollow/semi-hollow. I went to Compressed steel (a scrap yard here around town) and looked through the new scrap. I found a dozen bars 25' long 5"wide and 1 1/8" thick. I asked what they where and he said old railroad ties (Now I'm thinking railroad ties have a shape to them, so these must have been under the ties? as support?). I had him bring a torch over and cut them off in 4" pieces (so I ended up with 4"x5"x1 1/8" blocks). I started to drill the first one and it took forever to even scratch the surface and the bit was smoken, even after I added a little oil. So I ran to the machine shop with my 10 blocks and had then drill them in the drill press. I believe I paid $45 for the steel and $15 for the machine work. They are roughly 6-8 lbs each, but they increased my surface area for the mounts and made a nice lift to boot. On the next project /forums/images/graemlins/k5.gif I may try the ORD lift pucks (I believe they are round and aluminum).
