body lift issues
Discussion in 'The Garage' started by SUPERSUB87, Dec 12, 2006.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    might be a stupid question...
    how do you loosen up the steering shaft for the body lift?.. and how do you get to the clutch linkage to lengthen it with the weld in piece?
    also would some sealant or loctite help keep the 2 pucks inside the rear quarter panels (the pucks with no bolts in them) from sliding out like some have said they do at full flex?
    also for future reference.. how much fender trimming would be needed to fit 42's or 44's on a 10" lift??? thanks for all of ya'lls help
  2. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    if ur talking about a 2" body lift, i just loosened the 2 bolts that hold up the column and it says it slides down but i didnt see any movement really and my steering is still fine. about the cluth linkage...i have a 700r but my friend did a 3" body lift with a 465 and he just put it on the spot that looked like it had to drop, basically any straight section of the linkage, i just crawled under my truck and pictured how it would move and put it in a place i felt was good and i cant help u with the rear mount question...i have a k5 so mine were all bolted in...and trim, just do what u think would be good, just look at other guys trucks, u can always cut more but u cant put back on. hope this help u, good luck
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Inorder to keep the stock clutch linkage in place you can't go any higher than a 1.5 inch body lift or so. At least that is how it is on my 85 K10.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    On my sub, I didn't adjust the steering. I used spacers that fit the holse for the non-boly on mounts. I bolted the spacers to the pucks. I did an ORD 1".
  5. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I have a 3" with a mechanical clutch linkage, and it works. Cut the shaft after it comes through the firewall, at a straight spot, and weld it in. The steering shaft will have to be heated to get the nylon locks out, the lengthen it that way. Its best to remove the entire shaft to do this. Dont know about the ones without bolts.
  6. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    thanks this is exactly what i needed. i got a 3" body lift so this helps a lot. I'm not sure about my clutch linkage though. i have a manual 3-speed with a low gear. is that the sm465 or what?:confused:
  7. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    L 2
    3 4
    If it looks like that it mostly likely is. Ill take a pic of mine tomorrow if that will help.
  8. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    im pretty sure its like this
    L 2
    1 3 R
    but im not 100% positive, but pretty sure.
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    thats the pattern on my 465
  10. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    yeah, that's what i thought it was. I changed the clutch in it last summer. (still havent been able to drive her:( :( :( ) i thought thats what was stamped on the side but i wasn't sure. Can't wait till i get to drive may baby, even in 2wheel drive it would be fine for me, i just want to be able to start it.:(
  11. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Its much better if you go by the pattern:
    1 2
    3 4 R
    At least it makes it seem more sporty :doah:
  12. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    I messed that all up
    L 2
    1 3 r
