Body lift on a CUCV?
Discussion in 'The Garage' started by Lotsa_Faith, Sep 30, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    What all would I have to hack to put one on a cucv? Those hooks go through the bumpers off the frame, and therers alot of rivets under there too...
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What does the bumper have to do with a body lift?
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    usually when you do a body lift you raise the bumper to avoid the ugly gap that appears with a body lift. Military vehicles have the helicopter hooks sticking out the square holes in the bumper.
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    when you do a body lift, basically you are lifting the body off the frame, everything attached to the frame stays put, like bumpers, engine, tranny ect; the gas tank filler hose and all wires will be stretched by the amount of the lift, your shifter rod will need a piece welded in to make up for the size of the lift,
    it is really not that hard and you may want to think about putting some poly body bushings under there while you are at it
  5. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I put a 2" BL on my M1009 when I swapped in the 500 Caddy. It was real easy to do. The only thing I screwed up /forums/images/graemlins/blush.gif was forgetting to unhook the tailgate springs which were causing me to lift the whole truck when jacking on the body and I forgot to unhook the body-engine ground wire which I promptly ripped in two. I left the bumpers where the were. No ill effects so even when the 500 came out and the 6.2 went back in, I said screw it and left the BL on it enjoying more tire clearance. You'll be surprised how nasty your bolts and bushings are when you take them out /forums/images/graemlins/shocked.gif
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ] Oh, yeah! mine were rusted down to about the diameter of a 1/4bolt. /forums/images/graemlins/crazy.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You might do that if you only wanted your bumpers for appearance purposes only!
