Body Lift on the burban
Discussion in 'The Garage' started by or2play, Oct 18, 2002.
  1. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Got my body lift done on my suburban. Finally starting to make some noticable progress on my truck. Also replaced the orignal bushings that were shot with some energy suspension pieces. Wow, what a differance.
    The body lift would have went smoothly, except the bolts in the bed were completly rusted into the bushing. Ya it was fun removing them. A lot of yelling cursing and a lot of cutting, pounding, and grinding.
    But worth the effort. Any questions about doing a body lift or what to expect, by all means fire away.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    HAHAHA mine weren't rusted at all!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif c'mon everybody leave the rust behind and move to vegas!!
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I was doing a lot of this also when i did mine a few months back.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Me, Me...I've got a question.
    What products did you use...cost...how much lift...did you have to extend any of your linkage?
    Because I was thinking of doing the same thing as you (since my bushings need replacing badly) and I'd probably do a 1" (can I even find that?) body lift. Just to be sure I can fit 35" tires.
    Also, the bolts near the rear axle, that aren't really bolts, how did you manage those? Maybe Muddysub can clear this up because I think I've heard him talk about them before.
    Thanks in advance.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Me, I bought new energy poly bushings and my 2" body lift from 4hill 4wd (was roughly $160 for the both).
    If your only going to go with a 1" body lift, then no, all your linkage will be fine, will be fine with a 2" also. You can get a 1" body lift from ORD.
    The 4 bolts that you are talking about that aren't really bolts, the stock bushings are just sandwiched between the frame and body, when you put in your body lift, you will have to drill holes in the body only, holes alread exist in the frame(they are the 2 mounts in front of the rear axle and the 2 mounts behind the rear axle).
    Any more questions, fire away.
  6. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the info.
    I guess I'm still not with you on the rear bushing thing. I have to drill a hole through the body? (like pull up the carpet and drill from the top down?) Then what do I do. Once I put the new ones in do I secure them in any way.
    Sorry, I'll catch on sooner or later.
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i think maybe he means to drill a whole through the cab supprt that is atatched to the body that meets the frame..or am i wrong?
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A picture is worth a thousand words. So please post some pics (if you have any) for all of us who have never installed a body lift befor.
  9. muddysub
    Jun 23, 2001
    10,452
    489
    ok there are 4 mounts on a suburban that don't have bolts in them, just a bushing sandwiched in there. you will have to lift up the carpet, find the right spot and drill a hole in the floor to put a bolt through. also you will have to get the bottom half of the bushing (rubber part and cup for the bottom) and run a set of bolts through them. i'll try to get pics tomorrow.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thanx
  11. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    I used energy poly bushings, and a 2 inch kit from performace accessorys. One thing I had to do is get some new bolts for a few mounts. The poly bushings aren't as thick as the orignals.
