Body Lift or Not
Discussion in 'The Garage' started by txfireman110, Apr 20, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Right now, I have a 3" body lift. I have been debating wether to remove it or not when I start the Overhaul. What do ya'll think? The "overhaul" which will begin in a couple of weeks, will consist of:
    1. 1 ton axles /forums/images/graemlins/woot.gif
    2. 454/TH400 /forums/images/graemlins/woot.gif
    3. Shock Towers in Front, ? in back.
    4. 38.5x14.50 TSL/SX on 15x10 Black Steelies.
    5. Misc. other stuff such as bumpers, etc, etc. /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
    I think the body lift will benefit in room for the 454, and more room for shock towers, but what would ya'll do?
    PS-Rig will be used in rocks, mud, trails, whatever else, but no DD.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Im not a big fan of large body lifts but if its already in, you are happy with it and everything is working properly I'd just leave it alone. Otherwise I'd go with a 1" or none. Just my opinion /forums/images/graemlins/dunno.gif
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    body lifts suck.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Body lift, I think not! /forums/images/graemlins/yikes.gif
  5. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I have had some people tell me that they have seen the pucks used to lift a body punch a hole right through a body from hard four wheeling.
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    body lifts suck.
    Why do body lifts suck?
    Throw out statement like that and the least you could do would be to share your experance as to why /forums/images/graemlins/thinking.gif
    Oh,and I have been running a 2" (and a 3" before that)body lift on my truck for 10+ years.Never have had any problems related with it.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    IMYO I think that 1" body lifts are okay, but bigger should only be when you cant use any more lift springs (I.E. 12" spring lift.) I can't say that really though because I have never used a body lift /forums/images/graemlins/dunno.gif
  8. kevin's87
    kevin's87 Registered Member
    Jan 21, 2004
    6
    San Angelo, TX
    /forums/images/graemlins/shame.gif /forums/images/graemlins/shame.gif
  9. unick
    Aug 16, 2003
    4,286
    body lifts suck.
    I think they suck because they look terrible. Personally I dont fell safe riding on a few 3" pieces of plastic. A 1 inch is OK I would consider using one of them but ahything more than that looks like crap to me.
    NIck
  10. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    I was also wondering why everyone always talk bad about bodylifts. I've had 3" bodylifts on 3 different trucks running 38" tires or bigger and wheeled all three with no problems. It seems people who give these negative opinions have either never run a bodylift or never had a problem with one, but they heard stuff. Also why would you say you would run a 1" but say a 2" or 3" is no good? Just because ORD sells a 1" doesn't make it wrong or right. The body isn't bolted to the frame stock anyway, so like it or not your already running a bodylift. A bodylift is a good way to gain clearence for larger tires without affecting ride quality, flex, axle wrap, etc. My $.02.
  11. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I did the same thing last year, i was running a 3" and ordered a ORD 1" but when it comes down to it why??? Alot of people will pipe up about how bad they are but i dont see any problems with them, Iv had mine in for over two years with 40" tires and wheel it locally alot and took it to Uhwarrie, did all those trails without a concern. I will never take it out do to the clearance it provides for access to the gas tank, t case, plus i have a crossmember running on top of my frame for upper shock mounts in the back that i couldnt do with none or a 1". If its not broke dont fix it /forums/images/graemlins/waytogo.gif
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have a 3" body lift in the garage, I plan on cutting it down to 1.5" maybe 2". I have 1.25" body lift on my DD, I cruise the highways about 75 and take turns (with the swaybar connected) probley faster than I should.... No problems so far (*knock on wood*)
    If its already in I'd say leave it. If its that big of a worry to you, pull it out and cut it down to 1.5" /forums/images/graemlins/waytogo.gif
  13. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Cutting it down is kinda what I was leaning towards. I am concerned that after 4" suspension, 3" body, and 38s or so, it'll be too tall. /forums/images/graemlins/dunno.gif, but I like the extra clearance for the 454 and shocks, etc.
    I'll prolly cut the body down to 1.5" like you said.
  14. sapper
    Jul 11, 2001
    3,052
    NoVa
    here is mine with a 5 and 3 lift with 40s just for a idea of what it would sit like
