Body Lift/Poly Body Bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefheaphy, Mar 19, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Did I get jipped two bushings halves with this kit?
    I have the front six. I am confused with the rear mounts. DO I need to dig through my trashbarrel to reuse old parts?
    I know I need one more retaining washer also.
    Thanks,
    Heaph
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Did you buy the kit new?
  3. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Yeah. I feel like I am missing two bushing lowers unless the rear most mounts only have a bushing between the frame and body. Doesnt really make sense. Should I get on the horn?
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Definitely.
  5. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Did I use the word jipped?
    SO basically there should be 20 bushings. 10 upper...10 lower
    Not 18
    God dammit!
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    For what rig? Regular cab, crew, blazer?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Where did you get the retaining washers? They come with the kit? Which kit? Body lift or bushings?
    You know you still need the upper part of the washer thingies that sit between the BL and bushing. Its a cup shaped steel insert that fits in the upper bushings.
  8. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    blazer.
    the washers came from the blazer im rebuilding. reuse.
    The poly kit is "Prothane" for an 88 k5
    The body lift is a trailmaster.
    For something that seems so f-in simple, this is a hassle.
    so...the lift blocks dont just sit on the upper poly bushing?
    Thanks for the help man.
    -heaph
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, the BL sits on top of a metal cup shaped part that the bushing slides onto first. Let me get a picture of them as I have new bushings and the factory washer hardware to show you what I mean.....
    Give me a few minutes.....
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, got a few pics of mine.
    Be aware the upper steel part is the '81 and '82 years only. '83 on up have a different type.
    You should have at least 6 of these, two for the radiator support, 2 for the front cab, 2 for the rear cab and the rest under the tub.
    Since I've never removed a K5 tub from a frame, I can't tell you how many more of these steel parts you need.
    Somebody else should chime in soon.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sorry about the crappy pics. And the shiny round thing you see in the pic is the ORD 1" body lift puck. I just threw it in for show.
  12. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    nice
    pics are always a huge help.
    thnx 30guy!
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    No prob.
    You should have those upper steel parts in your K5. I'd be surprised if you didn't.
