Body lift puck question
Discussion in 'The Garage' started by Yukon Jack, Aug 26, 2002.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm needing 2" body lift pucks and want to use aluminum like ORD sells. A friend works at a machine shop and can build them to my specs as ORD only has 1" aluminum pucks.
    Should the center hole be the diameter of the body mount bolt or should I make it the same diameter as the body mount bolt hole? Looks like the body mount bolt is 7/16" but the body mount holes are 3/4".
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    On the ORD ones they are the size of the bolt 1/2..or a tiny bit bigger.
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I would make it just large enough for the bolt to go through.
    Ken H.
  4. SHINTON
    SHINTON 1/2 ton status
    Dec 26, 2001
    148
    Kernersville, NC
    I assume your buddy is doing this el cheapo but, what are the 'considerations' of having the alum pucks vs the hard plastic ones I can buy from all over the net?
    I am looking at 2-3" lift this fall and ORD just has the 1" so they are out. ORD, if you are reading this, why not do the 2 or 3" pucks? (I understand the taller the more 'stress' concept)
  5. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    My buddy will do it for free and I like free. I wanted aluminum cause I have heard that the plastic ones can sometimes break. + aluminum has a coolness factor and strength.
    I'm doing 2" for two reasons, one to get my cab to line up a little better with my flatbed's headache rack, and two for clearance for a 454 I'm preparing to swap in.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ? # 2
    if we make homemade pucks does there need to be any kind of indentions on the ends or just a solid piece of stock with the hold in the middle? I know a lot of the plastic ones are half hallow but that is just injection molding and less material so it's cheaper....
    I'm thinking about going with a 5-6" body lift so I wont have to buy expensive springs LOL J/K
  7. UseYourBlinker
    Jun 7, 2000
    11,117
    Good idea /forums/images/icons/wink.gif
  8. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I recently saw a guy with about that much in a body lift. He used rectangular tubing and I bet they were 8" to 10" tall. It was a sight to see.
    He could probably do a carb swap without lifting the hood there was such a big gap between the frame and body. Each to their own I guess!
  9. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've only got a 1" body lift installed, and the 454 has room to spare... Just my .02! /forums/images/icons/grin.gif
